Windshield Wiper
1 Answer 0 Score |
Hyundai Accent el freni sorunu |
1 Answer 0 Score |
P0730 Gear ratio incorrect (pulley) |
2 Answers 2 Score |
The low beams on my 2014 Accent aren't coming on. |
2 Answers 0 Score |
My front bumper is coming loose |
Checking Cables and Wires
- Check the terminal for tightness.
- Check terminals and wires for corrosion from battery electrolyte, etc.
- Check terminals and wires for open circuits.
- Check wire insulation and coating for damage, cracks, and degrading.
- Check the conductive parts of terminals for contact with other metallic parts (vehicle body and other parts).
- Check grounded parts to verify that there is complete continuity between their attaching bolt(s) and the vehicle''s body.
- Check for incorrect wiring.
- Check that the wiring is so clamped to the prevent contact with sharp corners of the vehicle body, etc. or hot parts (exhaust manifold, etc.)
- Check that the wiring is clamped firmly to provide enough clearance from the fan pulley, fan belt and other rotating or moving parts.
- Check that the wiring has a little space so that it can vibrate between fixed and moving parts such as the vehicle body and the engine.
