2015 Nissan Micra Interior Dome Light Replacement
  1. 2015 Nissan Micra Interior Dome Light Replacement, Dome light: step 1, image 1 of 3 2015 Nissan Micra Interior Dome Light Replacement, Dome light: step 1, image 2 of 3 2015 Nissan Micra Interior Dome Light Replacement, Dome light: step 1, image 3 of 3
    • Remove the plastic covering for the interior dome light. using your hands or an opening tool.
    • There are clips securing the cover so be sure to undo them as you remove the cover.
    • Because of the delicacy of the covering, it is recommended that you use your hands, however even with your hands proceed with caution as to not break the lid and/or clips.
  2. 2015 Nissan Micra Interior Dome Light Replacement: step 2, image 1 of 2 2015 Nissan Micra Interior Dome Light Replacement: step 2, image 2 of 2
    • Make sure the light bulb isn't hot before taking it out.
    • If it's still hot, wait about 30 seconds to a minute and the bulb should cool down enough to take it out.
  3. 2015 Nissan Micra Interior Dome Light Replacement: step 3, image 1 of 2 2015 Nissan Micra Interior Dome Light Replacement: step 3, image 2 of 2
    • Remove the light by pulling out the bulb from the socket.
    • If you are having trouble pulling out the lightbulb, try lightly wiggling the bulb until it is loose enough to pull out.
  4. 2015 Nissan Micra Interior Dome Light Replacement: step 4, image 1 of 3 2015 Nissan Micra Interior Dome Light Replacement: step 4, image 2 of 3 2015 Nissan Micra Interior Dome Light Replacement: step 4, image 3 of 3
    • Replace the dead or broken bulb with a new bulb and insert it into the socket.
    • The socket for a Nissan Micra is a W5W bulb.
    • When replacing the bulb, make sure you have the power switch off so you don't burn yourself.
    • The light bulb is delicate so when putting the bulb into the socket to not apply too much force or else you may break the bulb.
  5. 2015 Nissan Micra Interior Dome Light Replacement: step 5, image 1 of 2 2015 Nissan Micra Interior Dome Light Replacement: step 5, image 2 of 2
    • Turn on the light by pressing the switch to make sure the bulb and socket works.
    • If it does work then your light should be shining similar to the photos shown.
  6. 2015 Nissan Micra Interior Dome Light Replacement: step 6, image 1 of 3 2015 Nissan Micra Interior Dome Light Replacement: step 6, image 2 of 3 2015 Nissan Micra Interior Dome Light Replacement: step 6, image 3 of 3
    • Place the covering for the light back into place.
    • There are six holes on the light assembly and each of them connects to a specific clip of the lid.
    • Use your fingers to press the lid into place and you are done, You now have a new light that'll light up your car.
Sanjeev Visvalingam
133 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 33
All Time: 935
