Introduction
Use this guide to replace the adhesive of your Apple Watch Series 3 and reseal it.
This guide shows the procedure on the standard, GPS-only version of the watch, but the cellular/LTE version is similar. Any important differences are noted in the text.
Tool used on this step:Adhesive Cleanup Kit (Set of 12)$4.99
Apply a little bit of isopropyl alcohol (>99%) to a Q-tip or use a cleaning pad to gently remove the adhesive leftovers on top of the force touch gasket.
Flip the Apple Watch upside down so the display lays flat while lifting up the case.
Remove the leftovers on the back of the display.
Use a pair of tweezers to carefully remove replacement adhesive with the blue protective film from the backing paper.
Hold the replacement adhesive diagonally to thread it over the display.
Slightly tilt the display forward so you can align the adhesive with the frame.
Position the replacement adhesive on top of the force touch gasket and use the pointed end of a spudger to move and press it into place.
29 other people completed this guide.
7 Comments
My adhesive gasket I ordered from you doesn’t not look like the one you use. I don’t see how it could work either.
My adhesive was larger than the rim so it had about 5-6 mm bump of extra plastic when I got it in the edge all around. Need it to be sealed so I didn't want to cut anything. Fail.
Yes mine was also larger than the adhesive seal that is advertised here.
We believe this adhesive kit does not work all the time. there is still risk that with slightly water in-contact during activity, screen may slightly raised again. I think using glue E-8000 after wiping the edges of the watch with isopropyl is a good idea for long term safety.
The Tesa adhesives that you sent are simply aweful. The cuts aren’t deep enough to safely remove the replacement adhesive with the blue protective film from the backing paper. Plus when you actually manage to do so, the adhesive’s dimensions are a bit short for the Series 3 42mm model.
