This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Apple iPod Dock Connector Cable Replacement
  1. Apple iPod Dock Connector Cable Replacement, iPod Dock Connector Cable: step 1, image 1 of 3 Apple iPod Dock Connector Cable Replacement, iPod Dock Connector Cable: step 1, image 2 of 3 Apple iPod Dock Connector Cable Replacement, iPod Dock Connector Cable: step 1, image 3 of 3
    • Unscrew the four Phillips screws on the backside of the docking system.
    • The screws are located quite deep. Make sure you have a long screwdriver to be able to reach the screws.
    • Be aware of the plastic threads. Using too much force can tear this up.
  2. Apple iPod Dock Connector Cable Replacement: step 2, image 1 of 1
    • Separate the housing in two parts.
    • The dock connector is slid in two parts on the top of the system, make sure you slide the two housing parts in this line of direction.
    • The two parts are glued on the sides of the speakers. Use some force to separate the two housing parts.
    • The internal parts are still connected to each other. Don't pull the housing parts too far from each other.
  3. Apple iPod Dock Connector Cable Replacement: step 3, image 1 of 1
    • Slide the dock connector out of the housing part.
  4. Apple iPod Dock Connector Cable Replacement: step 4, image 1 of 1
    • Unscrew the three screws using a Phillips #2 screwdriver to remove the T-shaped circuit board holder.
  5. Apple iPod Dock Connector Cable Replacement: step 5, image 1 of 1
    • Remove the T-shaped circuit board holder.
  6. Apple iPod Dock Connector Cable Replacement: step 6, image 1 of 1
    • Remove the circuit board from the housing part.
    • The circuit board is still connected to another circuit board with a cable.
  7. Apple iPod Dock Connector Cable Replacement: step 7, image 1 of 1
    • Disconnect the 5-pin connector between the two circuit boards.
    • The connectors are tightly connected. Hold the other circuit board to prevent it from breaking while disconnecting the 5-pin connector.
  8. Apple iPod Dock Connector Cable Replacement: step 8, image 1 of 2 Apple iPod Dock Connector Cable Replacement: step 8, image 2 of 2
    • Look how the cables are oriented.
    • Take a picture with your phone. It's easier to look it up than recalling your memory.
  9. Apple iPod Dock Connector Cable Replacement: step 9, image 1 of 1
    • Trigger the desoldering pump before heating the solder.
  10. Apple iPod Dock Connector Cable Replacement: step 10, image 1 of 1
    • Heat up the solder.
    • If you don't want to damage your workspace, it's probably handy to place something underneath.
    • The circuit board will be getting hot. To make it more stable you can clamp it in a vise or alligator clips.
    • The heated solder tends to fumeā€”do not inhale this! Do this in a well ventilated room.
  11. Apple iPod Dock Connector Cable Replacement: step 11, image 1 of 2 Apple iPod Dock Connector Cable Replacement: step 11, image 2 of 2
    • If the solder becomes fluid, keep the desoldering pump near the solder.
    • Push the button on the desoldering pump to suck the solder.
    • Solder will solidify fast, so you need to act quickly.
  12. Apple iPod Dock Connector Cable Replacement: step 12, image 1 of 1
    • Strip the cables with a wire stripper.
  13. Apple iPod Dock Connector Cable Replacement: step 13, image 1 of 2 Apple iPod Dock Connector Cable Replacement: step 13, image 2 of 2
    • Check if the cable is in the right position.
    • Heat up the contact point on the circuitboard.
    • If the contact point is hot enough, you can add a little bit of solder.
    • Don't inhale the fumes.
To reassemble your device, follow these instruction in reverse order from step 7
Special thanks to these translators:
nl en
94%
These translators are helping us fix the world! Want to contribute?
Start translating ›
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 22
All Time: 479
