Bread toaster repair - home built tools (Mica Plate Punch)
  1. Bread toaster repair - home built tools (Mica Plate Punch), Bread toaster repair - home built tools (Mica Plate Punch): step 1, image 1 of 3 Bread toaster repair - home built tools (Mica Plate Punch), Bread toaster repair - home built tools (Mica Plate Punch): step 1, image 2 of 3 Bread toaster repair - home built tools (Mica Plate Punch), Bread toaster repair - home built tools (Mica Plate Punch): step 1, image 3 of 3
    • Homemade tool, for the repair of bread toasters, in this case it is the perforator for the mica sheet, which will allow us to insert a screw that will join the two ends of the Nicrom thread, split, it is the 3rd tool that I have made when in fact it should have been the first.
    • This is the most basic and simple to make, it is the first one we will use in the repair, it is made with a chopstick, a small wood screw and a small nail, both reinforced with instant dry glue.
  2. Bread toaster repair - home built tools (Mica Plate Punch): step 2, image 1 of 2 Bread toaster repair - home built tools (Mica Plate Punch): step 2, image 2 of 2
    • Measure the nail with Caliper or "caliper foot" to use the most appropriate drill bit, in this case a thin nail of 2 mm.
  3. Bread toaster repair - home built tools (Mica Plate Punch): step 3, image 1 of 2 Bread toaster repair - home built tools (Mica Plate Punch): step 3, image 2 of 2
    • Inserting the nail, we must make the guide hole with the drill bit, this step is very important, otherwise the end of the stick will crack, before inserting the nail completely we will apply a drop of instant drying glue type cianolit so that it does not move with use.
  4. Bread toaster repair - home built tools (Mica Plate Punch): step 4, image 1 of 3 Bread toaster repair - home built tools (Mica Plate Punch): step 4, image 2 of 3 Bread toaster repair - home built tools (Mica Plate Punch): step 4, image 3 of 3
    • Now we will do the same with the screw, we will use a drill bit slightly smaller than the screw we have once the hole is drilled, with a drill bit of larger diameter (the size of the screw head) we will make a slight "countersink" so that the head when tightening the screw is embedded.
  5. Bread toaster repair - home built tools (Mica Plate Punch): step 5, image 1 of 3 Bread toaster repair - home built tools (Mica Plate Punch): step 5, image 2 of 3 Bread toaster repair - home built tools (Mica Plate Punch): step 5, image 3 of 3
    • We place the screw and tighten it, and when there are 3 or 4 mm left to finish tightening, we apply a drop of instant dry cyanolit and we finish tightening.
  6. Bread toaster repair - home built tools (Mica Plate Punch): step 6, image 1 of 1
    • View of the inserted screw.
  7. Bread toaster repair - home built tools (Mica Plate Punch): step 7, image 1 of 3 Bread toaster repair - home built tools (Mica Plate Punch): step 7, image 2 of 3 Bread toaster repair - home built tools (Mica Plate Punch): step 7, image 3 of 3
    • Images of the finished set.
  8. Bread toaster repair - home built tools (Mica Plate Punch): step 8, image 1 of 2 Bread toaster repair - home built tools (Mica Plate Punch): step 8, image 2 of 2
    • View of the finished homemade tool, useful to pierce the mica sheet at the point of breakage of the Nicrom thread in toasters and to be able to repair the thread. This tool is a complement of the following tools, being this the first one to be used to make the repair.
    • This is the 2nd tool that we will use in the repair of toasters with broken or broken nichrome wire, with this one we hold and place the screw: https://es.ifixit.com/Gu%C3%ADa/HERRAMIE...
    • This other tool is another option to the homemade tool 2nd is another model of homemade tool for fastening screws: https://es.ifixit.com/Gu%C3%ADa/HERRAMIE...
    • This tool will be used to illuminate the inside of the toaster: https://es.ifixit.com/Gu%C3%ADa/HERRAMIE...
    • Example of the use of the tools, in this case I used the first ones I made: https://es.ifixit.com/Gu%C3%ADa/TOSTADOR...
This tool is a complement to the homemade tools already published; whose purpose is the repair of broken Nicrom thread in bread toasters:
Special thanks to these translators:
es en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Carlos López (España - Spain)
55,080 Reputation
166 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,501 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 18
All Time: 204
