This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
why! N131WU screen replacement
  1. why! N131WU screen replacement, LCD: step 1, image 1 of 3 why! N131WU screen replacement, LCD: step 1, image 2 of 3 why! N131WU screen replacement, LCD: step 1, image 3 of 3
    • Unclip the display bezel from the frame starting at the top.
    • To remove the lower part, open the display as far as possible.
  2. why! N131WU screen replacement: step 2, image 1 of 2 why! N131WU screen replacement: step 2, image 2 of 2
    • The LCD is secured with adhesive. Use an opening pick to separate the LCD from the display lid.
    • Carefully lay the LCD down on the keyboard.
    • Unplug the display connector at the bottom of the screen.
Special thanks to these translators:
fr en
40%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
31,100 Reputation
264 Guides authored
3 Comments
bonjour, pourriez-vous rajouter la manière dont on débranche le cable EDP entre carte mère et écran,
je n'ose pas tirer et je ne sais dans quelle direction! merci!
Didier Chakchouka - Reply
Step 14 of the why! N131WU Motherboard Replacement guide shows how to unplug the other end of the display cable from the motherboard. You will need to follow the first four steps of that guide in order to gain access to it.
Jerry Wheeler -
merci! je vais regarder cela!
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 18
All Time: 342
