Cracked Grout Replacement
  1. Cracked Grout Replacement, Cracked Grout: step 1, image 1 of 2 Cracked Grout Replacement, Cracked Grout: step 1, image 2 of 2
    • Identify the crack you will be repairing.
    • Surround it with Painters Tape.
  2. Cracked Grout Replacement: step 2, image 1 of 1
    • Wear protective eye wear and a mask to shield yourself from dust and debris.
    • Use caution when handling the concrete grinder. If handled improperly it can lead to an injury.
    • Use the concrete grinder to remove the grout surrounded with tape where the crack is located.
  3. Cracked Grout Replacement: step 3, image 1 of 2 Cracked Grout Replacement: step 3, image 2 of 2
    • Go in with your handheld grout remover and scrape out the remaining grout between the tile until it is completely hollow.
  4. Cracked Grout Replacement: step 4, image 1 of 2 Cracked Grout Replacement: step 4, image 2 of 2
    • Vacuum the dust and grout that was removed to reveal a clean and hollow space.
  5. Cracked Grout Replacement: step 5, image 1 of 1
    • Color match your grout by using grout samples to get your desired color of grout.
  6. Cracked Grout Replacement: step 6, image 1 of 3 Cracked Grout Replacement: step 6, image 2 of 3 Cracked Grout Replacement: step 6, image 3 of 3
    • Mix a scoop of grout and sealer to create a paste.
  7. Cracked Grout Replacement: step 7, image 1 of 3 Cracked Grout Replacement: step 7, image 2 of 3 Cracked Grout Replacement: step 7, image 3 of 3
    • Take the rubber grout float and press the grout paste securely into the crack.
  8. Cracked Grout Replacement: step 8, image 1 of 2 Cracked Grout Replacement: step 8, image 2 of 2
    • Take the grouting sponge and smooth out the grout evenly.
    • Let the grout sit and harden for twenty-four hours.
  9. Cracked Grout Replacement: step 9, image 1 of 1
    • Your new grout is dry and ready for use.
To repair any other cracks in grout, repeat these steps.
7 other people completed this guide.
Deanna Demydyak
429 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 5
Past 7 Days: 21
Past 30 Days: 135
All Time: 3,761
