Game Boy Advance Back Panel Replacement
Video Overview
  1. Game Boy Advance Back Panel Replacement, Remove the Battery Cover/Batteries: step 1, image 1 of 3 Game Boy Advance Back Panel Replacement, Remove the Battery Cover/Batteries: step 1, image 2 of 3 Game Boy Advance Back Panel Replacement, Remove the Battery Cover/Batteries: step 1, image 3 of 3
    • Take the battery cover off by releasing the locking tab and hinging the cover away. Remove the batteries inside the cover
    • Do not forget to remove the batteries! This applies to working with any electronic device as working with live electricity may damage the device or cause malfunctions
  2. Game Boy Advance Back Panel Replacement, Unscrew the Back Panel: step 2, image 1 of 2 Game Boy Advance Back Panel Replacement, Unscrew the Back Panel: step 2, image 2 of 2
    • Remove the six back panel screws using a Tri-wing Screwdriver.
    • Remove bottom back panel screw with a Phillips #1 screw driver. (Image #2)
  3. Game Boy Advance Back Panel Replacement, Remove the Back Panel: step 3, image 1 of 1
    • Remove the back panel by pulling away with one hand and the front secured in the other hand.
    • Removal of the back panel may cause shoulder buttons and side panels to come loose and fall off.
4 other people completed this guide.
Aldo Corona
799 Reputation
6 Guides authored
Cal Poly, Team 16-29, Maness Winter 2010 Member of Cal Poly, Team 16-29, Maness Winter 2010
CPSU-MANESS-W10S16G29
5 Members
61 Guides authored
One Comment
Seeing the GBA-SP guide, could information here be added so we know which mm triwing screws the regular GBA backpanel uses?
Renzo Guichelaar - Reply
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 93
All Time: 10,483
