GoPro Hero 3 Silver LCD Housing Replacement
  1. GoPro Hero 3 Silver LCD Housing Replacement, Battery: step 1, image 1 of 2 GoPro Hero 3 Silver LCD Housing Replacement, Battery: step 1, image 2 of 2
    • Pull back on the tab on the back of GoPro to open the battery cover.
  2. GoPro Hero 3 Silver LCD Housing Replacement: step 2, image 1 of 1
    • Pull the battery out using the tab.
  3. GoPro Hero 3 Silver LCD Housing Replacement, LCD Housing: step 3, image 1 of 2 GoPro Hero 3 Silver LCD Housing Replacement, LCD Housing: step 3, image 2 of 2
    • Use the plastic opening tool to remove the faceplate.
    • There is some adhesive and clips so be careful and the faceplate should pop right off.
  4. GoPro Hero 3 Silver LCD Housing Replacement: step 4, image 1 of 2 GoPro Hero 3 Silver LCD Housing Replacement: step 4, image 2 of 2
    • Now that the faceplate is off, it is time to remove the 4 screws on each corner.
    • Use the T4 tool bit from the iFixit toolkit in order to remove the 4 screws on each corner.
  5. GoPro Hero 3 Silver LCD Housing Replacement: step 5, image 1 of 2 GoPro Hero 3 Silver LCD Housing Replacement: step 5, image 2 of 2
    • Note: Make sure you remove the door cover of the USB, mini HDMI, and SD port before. Separating the motherboard will be easier.
    • Using the plastic opening tool, slowly pry open the motherboard assembly.
  6. GoPro Hero 3 Silver LCD Housing Replacement: step 6, image 1 of 2 GoPro Hero 3 Silver LCD Housing Replacement: step 6, image 2 of 2
    • Use the spudger to gently pry off the connector of the housing to the motherboard.
    • You should now have the motherboard assembly and the housing separated.
  7. GoPro Hero 3 Silver LCD Housing Replacement: step 7, image 1 of 3 GoPro Hero 3 Silver LCD Housing Replacement: step 7, image 2 of 3 GoPro Hero 3 Silver LCD Housing Replacement: step 7, image 3 of 3
    • Use the spudger to remove the heat shield tape and detach the image sensor from the motherboard.
    • Using the T4 Torx toolbit, remove the 4 screws that connect the sensor to the lens.
    • Remove the silver connector of the image sensor from the motherboard using the spudger to pry it off.
  8. GoPro Hero 3 Silver LCD Housing Replacement: step 8, image 1 of 3 GoPro Hero 3 Silver LCD Housing Replacement: step 8, image 2 of 3 GoPro Hero 3 Silver LCD Housing Replacement: step 8, image 3 of 3
    • The media adapter is attached to the motherboard via 3 screws:
    • x1 T4 Torx
    • x2 Phillips #00
    • There's a little silver bracket that is held down by the Phillips #00 screw so be careful not to lose it.
    • With a little prying, use the spudger to detach the media adapter's connector from the motherboard.
  9. GoPro Hero 3 Silver LCD Housing Replacement: step 9, image 1 of 3 GoPro Hero 3 Silver LCD Housing Replacement: step 9, image 2 of 3 GoPro Hero 3 Silver LCD Housing Replacement: step 9, image 3 of 3
    • Use the spudger to lift the black tab up to unlock.
    • Then remove LCD screen connector by sliding out.
  10. GoPro Hero 3 Silver LCD Housing Replacement: step 10, image 1 of 3 GoPro Hero 3 Silver LCD Housing Replacement: step 10, image 2 of 3 GoPro Hero 3 Silver LCD Housing Replacement: step 10, image 3 of 3
    • Using the Phillips head bit, remove the silver screw near the the top edge of the board.
    • Separate the LCD assembly by pulling away the motherboard.
  11. GoPro Hero 3 Silver LCD Housing Replacement: step 11, image 1 of 2 GoPro Hero 3 Silver LCD Housing Replacement: step 11, image 2 of 2
    • There are 3 Phillips #00 screws holding the lens onto the LCD housing that need to be removed.
    • Our screw on the top right is stripped, which is why it looks different. However, they will all look the same in your device.
  12. GoPro Hero 3 Silver LCD Housing Replacement: step 12, image 1 of 2 GoPro Hero 3 Silver LCD Housing Replacement: step 12, image 2 of 2
    • Carefully remove the camera lens from the LCD Housing.
    • Now you have the LCD housing removed!
5 other people completed this guide.
Brian Alvarez
1,439 Reputation
6 Guides authored
Cal Poly, Team 24-7, Lancaster Spring 2015 Member of Cal Poly, Team 24-7, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G7
3 Members
21 Guides authored
One Comment
Excellent walkthrough. Thank you Brian!
Nick Goulet - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 20
All Time: 8,677
