HP Deskjet 1055 Scanner Glass Pane Replacement
  1. HP Deskjet 1055 Scanner Glass Pane Replacement, Scanner Glass Pane: step 1, image 1 of 1
    • Take all paper out of the paper tray. Unplug the printer.
    • Remove the plastic printer-control panel on the top left.
    • Then, forcefully lift up the bottom of the panel while applying downward pressure with your thumb-as shown.
  2. HP Deskjet 1055 Scanner Glass Pane Replacement: step 2, image 1 of 2 HP Deskjet 1055 Scanner Glass Pane Replacement: step 2, image 2 of 2
    • With your other hand, slide the top of the panel towards the back of the printer.
    • Do not rip the white cable that connects the panel with the main body of the printer.
    • Disconnect the ribbon by pinching the blue tab and pulling away from the green circuit board.
    • Lift the panel free and set to the side.
  3. HP Deskjet 1055 Scanner Glass Pane Replacement: step 3, image 1 of 1
    • Place the plastic opening tool between the plastic cover and the mount on the printer.
    • Pry the plastic cover towards the center of the printer.
    • Pull up on the cover to remove it from the printer-as shown.
    • Repeat the process on the other side.
  4. HP Deskjet 1055 Scanner Glass Pane Replacement: step 4, image 1 of 1
    • To remove the glass panel, take out the four 14 mm (1/2 inch) screws with a T10 Torx screwdriver.
    • Don't lift the glass panel completely off because there are cables plugged into the underside.
  5. HP Deskjet 1055 Scanner Glass Pane Replacement: step 5, image 1 of 3 HP Deskjet 1055 Scanner Glass Pane Replacement: step 5, image 2 of 3 HP Deskjet 1055 Scanner Glass Pane Replacement: step 5, image 3 of 3
    • Disconnect the white cables from the green motherboard by pinching the cable where it connects to the green motherboard. Pull up, lightly.
    • Set the lower part of the printer aside.
  6. HP Deskjet 1055 Scanner Glass Pane Replacement: step 6, image 1 of 2 HP Deskjet 1055 Scanner Glass Pane Replacement: step 6, image 2 of 2
    • Place the glass panel, face down, on a smooth surface.
    • Remove the 14 mm (1/2 in.) screw from the white plastic tab on the side of the panel with a T10 Torx screwdriver.
  7. HP Deskjet 1055 Scanner Glass Pane Replacement: step 7, image 1 of 3 HP Deskjet 1055 Scanner Glass Pane Replacement: step 7, image 2 of 3 HP Deskjet 1055 Scanner Glass Pane Replacement: step 7, image 3 of 3
    • Remove the glass pane by carefully bending the plastic frame down from the side and sliding the glass pane out from the side.
Samuel Isbell
10 Reputation
1 Guide authored
Cal Poly, Team 9-18, Amido Fall 2012 Member of Cal Poly, Team 9-18, Amido Fall 2012
CPSU-AMIDO-F12S9G18
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 40
All Time: 3,894
