Handspring Visor Edge Screen Replacement
  1. Handspring Visor Edge Screen Replacement, Flip Cover: step 1, image 1 of 2 Handspring Visor Edge Screen Replacement, Flip Cover: step 1, image 2 of 2
    • Open the Visor Edge and place it on a table facing down.
    • Gently push the tab that connects the flip cover (top half) to the PDA (bottom half) upward, lift the pieces apart to detach them.
    • Do not pull on the flip cover in an attempt to remove it from the PDA.
  2. Handspring Visor Edge Screen Replacement, Back Panel: step 2, image 1 of 1
    • Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
  3. Handspring Visor Edge Screen Replacement: step 3, image 1 of 1
    • Remove the gray back plate from the PDA.
  4. Handspring Visor Edge Screen Replacement: step 4, image 1 of 2 Handspring Visor Edge Screen Replacement: step 4, image 2 of 2
    • Remove the four 2.6 mm Philips screws that are on the sides of the frame.
    • Remove the 3.9 mm Philips screw holding the stylus holster to the frame.
  5. Handspring Visor Edge Screen Replacement: step 5, image 1 of 2 Handspring Visor Edge Screen Replacement: step 5, image 2 of 2
    • Remove the four 2.6 mm Philips screws on the top and bottom of the frame.
  6. Handspring Visor Edge Screen Replacement: step 6, image 1 of 1
    • Gently remove the white frame from the back of the PDA.
  7. Handspring Visor Edge Screen Replacement, Screen: step 7, image 1 of 1
    • Place the PDA front face up.
    • Gently pull off the front cover.
  8. Handspring Visor Edge Screen Replacement: step 8, image 1 of 2 Handspring Visor Edge Screen Replacement: step 8, image 2 of 2
    Tool used on this step:
    Buy
    • Flip over the PDA.
    • Use the tweezers to remove the ribbon cable attaching the screen to the circuit board.
  9. Handspring Visor Edge Screen Replacement: step 9, image 1 of 2 Handspring Visor Edge Screen Replacement: step 9, image 2 of 2
    • Wedge the spudger in between the glass and the metal frame.
    • Slide the spudger down the length of the screen to detach from the frame.
    • With your hands, pry the screen up from the detached side. The screen will pop off.
Christian Valoria
201 Reputation
2 Guides authored
Cal Poly, Team 11-28, Maness Winter 2011 Member of Cal Poly, Team 11-28, Maness Winter 2011
CPSU-MANESS-W11S11G28
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 1,565
