How To Install a Mac SSD into an External Enclosure
  1. How To Install a Mac SSD into an External Enclosure, Disassemble the enclosure: step 1, image 1 of 3 How To Install a Mac SSD into an External Enclosure, Disassemble the enclosure: step 1, image 2 of 3 How To Install a Mac SSD into an External Enclosure, Disassemble the enclosure: step 1, image 3 of 3
    • Slide the SSD sled out of the metal enclosure to remove it.
  2. How To Install a Mac SSD into an External Enclosure, Install the SSD into the enclosure: step 2, image 1 of 3 How To Install a Mac SSD into an External Enclosure, Install the SSD into the enclosure: step 2, image 2 of 3 How To Install a Mac SSD into an External Enclosure, Install the SSD into the enclosure: step 2, image 3 of 3
    • Carefully insert your Mac OEM SSD as shown, with the golden contact pads below the connector pins facing upward.
    • The SSD and enclosure are both keyed, so the SSD can only be installed one way.
    • The SSD might take a significant amount of force to insert. Make sure you have the orientation correct before you apply any pressure.
    • When the SSD is fully inserted, the notch at the bottom of the drive should be aligned with the hole for the screw in the enclosure.
  3. How To Install a Mac SSD into an External Enclosure: step 3, image 1 of 1
    • Use a Phillips driver to install the 4.5 mm screw securing the bottom of the SSD.
  4. How To Install a Mac SSD into an External Enclosure, Reassemble the enclosure: step 4, image 1 of 3 How To Install a Mac SSD into an External Enclosure, Reassemble the enclosure: step 4, image 2 of 3 How To Install a Mac SSD into an External Enclosure, Reassemble the enclosure: step 4, image 3 of 3
    • Slide the SSD sled into the metal enclosure, SSD connector end first.
    • Make sure the enclosure is in the correct orientation—the sled slides in on the thin rails.
    • The USB-C port should be facing out once installed.
  5. How To Install a Mac SSD into an External Enclosure: step 5, image 1 of 3 How To Install a Mac SSD into an External Enclosure: step 5, image 2 of 3 How To Install a Mac SSD into an External Enclosure: step 5, image 3 of 3
    • Place the port cover plate onto the end of the enclosure, aligning the USB-C port with its cutout.
    • The screw hole chamfers should face outwards.
  6. How To Install a Mac SSD into an External Enclosure: step 6, image 1 of 1
    • Use a Phillips driver to install the two 8 mm screws onto the end of the enclosure.
  7. How To Install a Mac SSD into an External Enclosure, Use your new external SSD: step 7, image 1 of 1
    • The drive is now ready to be connected to your computer with either of the included USB cables.
Once your drive is installed, you can transfer data from it, or use Disk Utility to format it and use it as a Time Machine backup.
8 other people completed this guide.
Carsten Frauenheim
113,983 Reputation
338 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,187 Guides authored
4 Comments
Danke für das Teilen. Es wäre besser, wenn Sie ein zusätzliches Video-Tutorial haben. bloxorz
Halle Promise - Reply
The problem is that unless we're talking about a 2tb or larger SSD, the enclosure for an Apple SSD costs as much or more as just buying an external SSD (as I found out the hard way).
RD6 - Reply
Is there any driver that needs installed for this? My MacBook Pro, a MacBook Air, and a Windows machine do not recognize any USB storage device is being connected at all. Nothing shows up with Disk Utility.
Albert Einstein - Reply
Installed an original MacBook Air 11" Early 2014 SSD drive - doesn't work at all! Waisted €119,95
Raimondas Valuckas - Reply
Past 24 Hours: 35
Past 7 Days: 215
Past 30 Days: 944
All Time: 31,102
