How To Remove Rust From Old Tools
  1. How To Remove Rust From Old Tools, How To Remove Rust From Old Tools: step 1, image 1 of 2 How To Remove Rust From Old Tools, How To Remove Rust From Old Tools: step 1, image 2 of 2
    • Removing rust generally isn't dangerous, but it's pretty messy.
    • Prepare your workspace by laying out an old towel or shop rag that you won't mind getting dirty.
    • Consider also wearing protective gloves.
    • Place your tool on the towels.
  2. How To Remove Rust From Old Tools: step 2, image 1 of 2 How To Remove Rust From Old Tools: step 2, image 2 of 2
    • Spray the rusty areas of the tool with a generous amount of WD-40.
  3. How To Remove Rust From Old Tools: step 3, image 1 of 3 How To Remove Rust From Old Tools: step 3, image 2 of 3 How To Remove Rust From Old Tools: step 3, image 3 of 3
    • Use a scouring pad to thoroughly scrub the tool.
    • It shouldn't take a lot of force—the WD-40 and scouring pad will do most of the work.
  4. How To Remove Rust From Old Tools: step 4, image 1 of 3 How To Remove Rust From Old Tools: step 4, image 2 of 3 How To Remove Rust From Old Tools: step 4, image 3 of 3
    • Use a paper towel to wipe away the excess grime and WD-40.
  5. How To Remove Rust From Old Tools: step 5, image 1 of 1
    • Continue scouring the tool, adding more WD-40 as needed, until the surface is free of rust.
    • When you finish, your tool may not look brand new—but the surface should now be rust-free and ready for years of continued use.
8 other people completed this guide.
Geoff Wacker
90,075 Reputation
89 Guides authored
2 Comments
Apple cider vinegar removes rust well. Try it.
Michael Jucker - Reply
Thank you I have tried vinagar ,rust buster and other sprays and only the WD 40 worked best
Ronald Tyler - Reply
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 118
All Time: 4,488
