How to Clean Corroded Battery Terminals
  1. How to Clean Corroded Battery Terminals, Safety precautions: step 1, image 1 of 1
    • Wear gloves to protect your hands from the corrosion—it's a skin irritant.
    • If your device still works, power it down completely before starting.
  2. How to Clean Corroded Battery Terminals, Remove the batteries: step 2, image 1 of 3 How to Clean Corroded Battery Terminals, Remove the batteries: step 2, image 2 of 3 How to Clean Corroded Battery Terminals, Remove the batteries: step 2, image 3 of 3
  3. How to Clean Corroded Battery Terminals, Remove big chunks of corrosion: step 3, image 1 of 3 How to Clean Corroded Battery Terminals, Remove big chunks of corrosion: step 3, image 2 of 3 How to Clean Corroded Battery Terminals, Remove big chunks of corrosion: step 3, image 3 of 3
    • Use a toothbrush to gently remove any bigger chunks of corrosion from the battery terminals and battery recess.
    • Use the point of a spudger to pick out any bits that are stuck.
    • Pick around the batteries, and not at the batteries themselves.
    • Flip your device over and gently shake out the loose corrosion and debris.
    • Dispose of the corrosion and debris in the trash.
  4. How to Clean Corroded Battery Terminals, Remove any stuck batteries: step 4, image 1 of 2 How to Clean Corroded Battery Terminals, Remove any stuck batteries: step 4, image 2 of 2
    • You should now be able to remove any batteries that were previously stuck.
    • Clean out the battery recess with a toothbrush.
  5. How to Clean Corroded Battery Terminals, Clean the terminals: step 5, image 1 of 3 How to Clean Corroded Battery Terminals, Clean the terminals: step 5, image 2 of 3 How to Clean Corroded Battery Terminals, Clean the terminals: step 5, image 3 of 3
    • Alkaline batteries contain a base, which is what corrosion is made of. An acid like white vinegar or lemon juice will neutralize this base.
    • Lightly dip a cotton swab in white vinegar or lemon juice.
    • Don't soak the cotton swab. Only use a small amount of liquid at a time.
    • Gently rub the battery terminals with the cotton swab to dissolve and remove the corrosion.
    • The corrosion may fizz and bubble. Don't worry, this is normal.
    • Continue this process until there's no corrosion on the terminals.
  6. How to Clean Corroded Battery Terminals: step 6, image 1 of 3 How to Clean Corroded Battery Terminals: step 6, image 2 of 3 How to Clean Corroded Battery Terminals: step 6, image 3 of 3
    Tool used on this step:
    Microfiber Cleaning Cloths
    $3.99
    Buy
    • Isopropyl alcohol will remove any residue left from the previous step.
    • Lightly dip a cotton swab in highly-concentrated isopropyl alcohol (over 90%).
    • Gently rub the battery terminals with the cotton swap to remove any remaining residue from the previous step.
    • Wipe the residue away with a microfiber or lint-free cloth.
    • Repeat this process until the terminals are completely clean.
    • Wait two minutes to allow any residual alcohol to evaporate.
  7. How to Clean Corroded Battery Terminals, Install new batteries: step 7, image 1 of 3 How to Clean Corroded Battery Terminals, Install new batteries: step 7, image 2 of 3 How to Clean Corroded Battery Terminals, Install new batteries: step 7, image 3 of 3
Cleaning didn’t go as planned? Ask our Answers community for help.
For other electronics skills, click here.
2 other people completed this guide.
Spencer Day
55,203 Reputation
408 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,430 Guides authored
0 Comments
Past 24 Hours: 56
Past 7 Days: 307
Past 30 Days: 1,264
All Time: 5,393
