How to Fix a Broken Toilet Paper Holder
  1. How to Fix a Broken Toilet Paper Holder, How to Fix a Broken Toilet Paper Holder: step 1, image 1 of 1
    • As you can tell, the left holder is loose. Replacing the anchor is much needed.
  2. How to Fix a Broken Toilet Paper Holder: step 2, image 1 of 1
    • Remove the Allen screw under each holder.
    • I used a 1/6" Allen bit because that is what fit my toilet paper holder's Allen screw. Use the bit according to the screw available.
    • If the screw size is unknown, I would recommend buying a pack with several Allen bits and trying each until the right one is found.
  3. How to Fix a Broken Toilet Paper Holder: step 3, image 1 of 3 How to Fix a Broken Toilet Paper Holder: step 3, image 2 of 3 How to Fix a Broken Toilet Paper Holder: step 3, image 3 of 3
    • After unscrewing the holder, take it off and begin unscrewing the screws in the wall. The type of screwdriver depends on the screws used.
    • Remove the clip after removing all screws. You should be left with two big holes and two small holes in the wall.
  4. How to Fix a Broken Toilet Paper Holder: step 4, image 1 of 2 How to Fix a Broken Toilet Paper Holder: step 4, image 2 of 2
    • Remove the existing anchor and drill the top hole with the 5/16" drill bit. This will make space for the new anchor to be placed.
    • Pinch the new 3/8"-1/2" anchor, place it into the top hole, and push it to be level with the wall.
  5. How to Fix a Broken Toilet Paper Holder: step 5, image 1 of 2 How to Fix a Broken Toilet Paper Holder: step 5, image 2 of 2
    • After placing the new anchor in, align the clip accordingly and proceed to screw in the anchor, starting with the top hole and then the bottom hole.
    • You have the option to use a either a screwdriver or drill (head based on the screws in possession).
  6. How to Fix a Broken Toilet Paper Holder: step 6, image 1 of 2 How to Fix a Broken Toilet Paper Holder: step 6, image 2 of 2
    • When you have completed the previous step for both sides, place the toilet paper holder in place and re-screw the Allen screw until both holders feel stiff.
Finish Line
2 other people completed this guide.
Andrew Nammour
181 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 12
Past 7 Days: 65
Past 30 Days: 311
All Time: 23,534
