How to Install a 2.5" SSD Into a Silicone Enclosure
  1. How to Install a 2.5" SSD Into a Silicone Enclosure, Insert the SSD into the enclosure: step 1, image 1 of 2 How to Install a 2.5" SSD Into a Silicone Enclosure, Insert the SSD into the enclosure: step 1, image 2 of 2
    • Before you insert the new hard drive, note the orientation of the SATA connectors embedded in the enclosure:
    • The wide power SATA port
    • The narrower data SATA port
  2. How to Install a 2.5" SSD Into a Silicone Enclosure: step 2, image 1 of 3 How to Install a 2.5" SSD Into a Silicone Enclosure: step 2, image 2 of 3 How to Install a 2.5" SSD Into a Silicone Enclosure: step 2, image 3 of 3
    • Using the previous step, orient the new drive so that its SATA connectors will align with the enclosure's.
    • Slide the drive into the enclosure's opening.
    • Push the drive into the enclosure until it stops sliding and the SATA connectors are completely seated.
  3. How to Install a 2.5" SSD Into a Silicone Enclosure: step 3, image 1 of 3 How to Install a 2.5" SSD Into a Silicone Enclosure: step 3, image 2 of 3 How to Install a 2.5" SSD Into a Silicone Enclosure: step 3, image 3 of 3
    • Stretch the remaining enclosure corners over the drive so that the silicone cover encapsulates the drive.
Your drive is ready to be used!
3 other people completed this guide.
Arthur Shi
254,635 Reputation
529 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,430 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 45
All Time: 1,474
