How to Install an HID Conversion Kit
  1. How to Install an HID Conversion Kit, Headlights: step 1, image 1 of 2 How to Install an HID Conversion Kit, Headlights: step 1, image 2 of 2
    • Open the hood.
    • Locate the back of the headlights and remove the bolts holding the headlight housing.
  2. How to Install an HID Conversion Kit: step 2, image 1 of 1
    • Unplug the stock harness and remove the headlights.
  3. How to Install an HID Conversion Kit: step 3, image 1 of 2 How to Install an HID Conversion Kit: step 3, image 2 of 2
    • Remove battery negative terminal.
    • Remove headlight cover and remove factory halogen bulb.
  4. How to Install an HID Conversion Kit: step 4, image 1 of 1
    • Take out the HID bulb from the plastic shell and remove the circular plastic piece.
    • Remember not to touch the HID bulb glass!
    • If you accidentally touch it, you can clean it with some rubbing alcohol.
  5. How to Install an HID Conversion Kit: step 5, image 1 of 2 How to Install an HID Conversion Kit: step 5, image 2 of 2
    • Screw in the HID bulb back into the headlight housing.
    • Connect the wires of the HID bulb to the ballast and then connect the HID ballast back to the stock harness.
  6. How to Install an HID Conversion Kit: step 6, image 1 of 1
    • Before you mount the ballast, test the HID light to make sure it lights up.
    • If not, turn the adapter wire 180 degrees.
    • Mount the HID ballast with zip ties.
  7. How to Install an HID Conversion Kit: step 7, image 1 of 3 How to Install an HID Conversion Kit: step 7, image 2 of 3 How to Install an HID Conversion Kit: step 7, image 3 of 3
    • Put everything (like the headlight housing) back.
    • Enjoy!
Enjoy your new HID Conversion Kit and upgraded headlights or fog lights.
6 other people completed this guide.
Eric Wu
3,357 Reputation
23 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 90
All Time: 16,320
