How to Install an M.2 SSD
  1. How to Install an M.2 SSD, Reposition the standoff: step 1, image 1 of 2 How to Install an M.2 SSD, Reposition the standoff: step 1, image 2 of 2
    • If your laptop did not include a removable standoff or only supports one M.2 SSD form factor, you can skip this step.
    • Use a screwdriver to remove the preinstalled standoff.
    • If your laptop does not include a preinstalled standoff, you will need to get one.
    • Find the correct standoff location that corresponds to your desired M.2 SSD form factor.
    • Screw in the standoff.
  2. How to Install an M.2 SSD, Insert the SSD: step 2, image 1 of 3 How to Install an M.2 SSD, Insert the SSD: step 2, image 2 of 3 How to Install an M.2 SSD, Insert the SSD: step 2, image 3 of 3
    • Grip the SSD on the sides near the screw indent.
    • Gently slide the SSD into the socket at about a 30˚ angle.
    • The socket is spring loaded and will support the SSD at an angle.
  3. How to Install an M.2 SSD, Screw down the SSD: step 3, image 1 of 3 How to Install an M.2 SSD, Screw down the SSD: step 3, image 2 of 3 How to Install an M.2 SSD, Screw down the SSD: step 3, image 3 of 3
    • Use your finger to hold the SSD down horizontally, making sure that the screw indent aligns with the standoff.
    • Screw down the SSD to secure it.
  4. How to Install an M.2 SSD, Apply a thermal pad: step 4, image 1 of 3 How to Install an M.2 SSD, Apply a thermal pad: step 4, image 2 of 3 How to Install an M.2 SSD, Apply a thermal pad: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • If your laptop did not have a thermal pad installed, you can skip this step.
    • Use tweezers or your fingers to place a thermal pad on the top of the SSD.
    • The original thermal pad can be reused if it is clean and undamaged.
Installation didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
6 other people completed this guide.
Chayton Ritter
18,618 Reputation
102 Guides authored
Guide Team Member of Guide Team
Staff
6 Members
7,845 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 40
Past 30 Days: 226
All Time: 4,027
