How to Remove a Broken and Embedded Screw
  1. How to Remove a Broken and Embedded Screw, How to Remove a Broken and Embedded Screw: step 1, image 1 of 1
    • Use an angle grinder to grind the tip of the broken screw until its surface is smooth and even.
  2. How to Remove a Broken and Embedded Screw: step 2, image 1 of 2 How to Remove a Broken and Embedded Screw: step 2, image 2 of 2
    • Place a center punch in the middle of the tip of the screw.
    • Use a hammer to hit the center punch to make a dent in the center of the embedded screw.
  3. How to Remove a Broken and Embedded Screw: step 3, image 1 of 3 How to Remove a Broken and Embedded Screw: step 3, image 2 of 3 How to Remove a Broken and Embedded Screw: step 3, image 3 of 3
    • Place a center drill bit in the dent made in the previous step and start drilling until it expands enough to fit the standard drill bit inside it.
    • Always keep the drill bit at a 90 degree angle to the surface of the screw since tilting it can bend and break its tip.
  4. How to Remove a Broken and Embedded Screw: step 4, image 1 of 3 How to Remove a Broken and Embedded Screw: step 4, image 2 of 3 How to Remove a Broken and Embedded Screw: step 4, image 3 of 3
    • Make a hole in the tip of the screw by drilling with a standard drill bit.
    • Keep drilling until the hole reaches near the end of the screw.
  5. How to Remove a Broken and Embedded Screw: step 5, image 1 of 2 How to Remove a Broken and Embedded Screw: step 5, image 2 of 2
    • Insert a screw extractor in the hole and then hammer it inside, making sure it is tight.
  6. How to Remove a Broken and Embedded Screw: step 6, image 1 of 3 How to Remove a Broken and Embedded Screw: step 6, image 2 of 3 How to Remove a Broken and Embedded Screw: step 6, image 3 of 3
    • Using a wrench, unscrew the extractor.
    • The screw will come along with it, freeing the hole.
  7. How to Remove a Broken and Embedded Screw: step 7, image 1 of 2 How to Remove a Broken and Embedded Screw: step 7, image 2 of 2
    • Screw the new screw inside the freed hole.
Finish Line
3 other people completed this guide.
0 Comments
Past 24 Hours: 21
Past 7 Days: 93
Past 30 Days: 481
All Time: 6,833
