How to Remove scratches from a CD
  1. How to Remove scratches from a CD, How to Remove scratches from a CD: step 1, image 1 of 1
    • Identify any scratches.
    • Some scratches may be too deep to be removed. In this case, this method may not work.
  2. How to Remove scratches from a CD: step 2, image 1 of 2 How to Remove scratches from a CD: step 2, image 2 of 2
    • Take the CD to the sink.
    • Wash with lukewarm water to remove any dust or dirt.
  3. How to Remove scratches from a CD: step 3, image 1 of 1
    • Let the CD air dry, or dry with towel.
    • Use a non-linen towel or your CD will need to be washed again.
  4. How to Remove scratches from a CD: step 4, image 1 of 3 How to Remove scratches from a CD: step 4, image 2 of 3 How to Remove scratches from a CD: step 4, image 3 of 3
    • Take the toothpaste, and apply it to your index finger.
    • Rinse the toothpaste in lukewarm water and apply to the CD.
    • Rub toothpaste in a circular motion from the center to the outer edge.
    • Add multiple layers of toothpaste to cover all of the scratches.
    • Use a white toothpaste, not a gel. Gels containing little beads may cause more damage to the CD.
  5. How to Remove scratches from a CD: step 5, image 1 of 1
    • Let the CD sit for 2 to 3 minutes.
  6. How to Remove scratches from a CD: step 6, image 1 of 1
    • Rinse off the toothpaste with lukewarm water.
  7. How to Remove scratches from a CD: step 7, image 1 of 1
    • Let the CD air dry, or dry with a non-linen towel.
  8. How to Remove scratches from a CD: step 8, image 1 of 1
    • Inspect your disk.
    • If your disk still has scratches, repeat the process.
    • You could also try to burn the disk onto another disk if the disk is lagging.
40 other people completed this guide.
Nick Jones
1,389 Reputation
1 Guide authored
Cal Poly, Team 14-4, Green Fall 2015 Member of Cal Poly, Team 14-4, Green Fall 2015
CPSU-GREEN-F15S14G4
5 Members
16 Guides authored
5 Comments
thank youuuuuuuuu
aboabdo.2007 - Reply
Funziona anche con i DVD di film e videogiochi questo procedimento? Oppure รจ solo specifico per i CD?
Francesco Pepe - Reply
It did not work for me
Leisy Madrigal - Reply
Me Funciono muy bien, gracias!
Esteban Montero - Reply
Past 24 Hours: 34
Past 7 Days: 179
Past 30 Days: 1,120
All Time: 57,894
