How to Repair a Stuck Car Door Latch
  1. How to Repair a Stuck Car Door Latch, How to Repair a Stuck Car Door Latch: step 1, image 1 of 2 How to Repair a Stuck Car Door Latch, How to Repair a Stuck Car Door Latch: step 1, image 2 of 2
    • On the car door that will not close, examine the door latch located near the handle on the side of the door.
    • The car door latch will be locked in a closed position.
  2. How to Repair a Stuck Car Door Latch: step 2, image 1 of 3 How to Repair a Stuck Car Door Latch: step 2, image 2 of 3 How to Repair a Stuck Car Door Latch: step 2, image 3 of 3
    • Position a screwdriver between the legs of the locked door latch.
    • You may use any size screwdriver that will fit between the latch.
  3. How to Repair a Stuck Car Door Latch: step 3, image 1 of 1
    • Pull the exterior car door handle.
  4. How to Repair a Stuck Car Door Latch: step 4, image 1 of 2 How to Repair a Stuck Car Door Latch: step 4, image 2 of 2
    • While the exterior door handle is being pulled, push the screwdriver against the left leg of the latch.
  5. How to Repair a Stuck Car Door Latch: step 5, image 1 of 3 How to Repair a Stuck Car Door Latch: step 5, image 2 of 3 How to Repair a Stuck Car Door Latch: step 5, image 3 of 3
    • Use the screwdriver to push the latch upwards into the final unlocked position.
  6. How to Repair a Stuck Car Door Latch: step 6, image 1 of 2 How to Repair a Stuck Car Door Latch: step 6, image 2 of 2
    • Close the car door to ensure the latch has been properly reset.
Finish Line
11 other people completed this guide.
Kennedy Coleman
439 Reputation
1 Guide authored
14 Comments
Thanks a lot, you have saved me from one !&&* of a problem!
dee Knight - Reply
This helped me so much!! Thank you!!!
Jasmine Roman - Reply
Perfect. So simple. Excellent advice once again from iFixit. Thank you.
Bill Smith - Reply
Thank you so much! I figured it out because of this post!
Sharan Sahota - Reply
I love this solution. It literally just saved me. Thank you soo much.
Edith Turkson - Reply
Past 24 Hours: 203
Past 7 Days: 1,113
Past 30 Days: 5,108
All Time: 112,431
