How to Replace a Corroded Car Battery Terminal
  1. How to Replace a Corroded Car Battery Terminal, Car Battery Terminal: step 1, image 1 of 2 How to Replace a Corroded Car Battery Terminal, Car Battery Terminal: step 1, image 2 of 2
    • Remember to remove your car key from the ignition and shut off the car before performing this guide.
    • Locate the terminals on the top of the car battery. Next to each terminal is a positive(+) or negative(-) sign, indicating the charge.
    • The positive terminal looks to be in working order, but the negative end has a lot of corrosion buildup. This terminal needs to be replaced.
  2. How to Replace a Corroded Car Battery Terminal: step 2, image 1 of 2 How to Replace a Corroded Car Battery Terminal: step 2, image 2 of 2
    • Find the nut located on the side of the terminal.
    • Using an adjustable wrench, rotate the nut counterclockwise to loosen it.
    • Use an appropriately-sized wrench or socket, not channel locks as shown in the photo.
    • You do not need to loosen the nut all the way off the bolt, but just enough to loosen the terminal's grip on the node.
  3. How to Replace a Corroded Car Battery Terminal: step 3, image 1 of 2 How to Replace a Corroded Car Battery Terminal: step 3, image 2 of 2
    • Always remember to remove the negative terminal first before the positive terminal. This will prevent shorting to the ground and possibly causing shock or a fire.
    • Carefully use a rag to lift up the terminal off of the battery node.
    • Be cautious when handling battery corrosion, as it can irritate the skin and is harmful if it comes in contact with your eyes.
    • Place the terminal on a rag or towel and make sure it doesn't come in contact with the battery node.
  4. How to Replace a Corroded Car Battery Terminal: step 4, image 1 of 2 How to Replace a Corroded Car Battery Terminal: step 4, image 2 of 2
    • On the positive terminal, locate the nut along the side.
    • Using the wrench, rotate the nut counterclockwise.
    • You do not need to fully loosen the nut off the bolt, but just enough for the terminal to be easily removed from the node.
  5. How to Replace a Corroded Car Battery Terminal: step 5, image 1 of 2 How to Replace a Corroded Car Battery Terminal: step 5, image 2 of 2
    • Using a rag, carefully remove the positive terminal from the battery node.
    • Place the terminal on a rag or towel, and make sure it does not come into contact with the battery node.
  6. How to Replace a Corroded Car Battery Terminal: step 6, image 1 of 3 How to Replace a Corroded Car Battery Terminal: step 6, image 2 of 3 How to Replace a Corroded Car Battery Terminal: step 6, image 3 of 3
    • On the negative terminal, locate the nut on the side facing upwards.
    • Using the wrench, rotate the nut counterclockwise and remove it from the bolt.
  7. How to Replace a Corroded Car Battery Terminal: step 7, image 1 of 3 How to Replace a Corroded Car Battery Terminal: step 7, image 2 of 3 How to Replace a Corroded Car Battery Terminal: step 7, image 3 of 3
    • Take the wire plate on top and remove it carefully from the bolt.
    • At this point, it is fine to handle the metal plate with your hands since the terminals are disconnected from the battery and there is nothing completing the circuit.
    • Remove the bottom wire plate from the bolt, placing it carefully to the side.
  8. How to Replace a Corroded Car Battery Terminal: step 8, image 1 of 2 How to Replace a Corroded Car Battery Terminal: step 8, image 2 of 2
    • Set aside the old battery terminal, and replace it with the new one.
    • Replace the wire plates in the order they were taken off.
    • Although it is not necessary that the plates be placed in the same order again, it is generally a good idea to go with the order that it came in.
  9. How to Replace a Corroded Car Battery Terminal: step 9, image 1 of 2 How to Replace a Corroded Car Battery Terminal: step 9, image 2 of 2
    • Place the flat washer and the screw-on head that came with the battery terminal onto the vertical bolt.
    • Tighten the head clockwise and make sure the wire plates are secured.
    • Not all battery terminal packs come with a washer and screw-on head. If your pack comes with a nut, use the wrench and tighten the bolt clockwise.
  10. How to Replace a Corroded Car Battery Terminal: step 10, image 1 of 1
    • Using a rag, place the positive terminal back onto the positive node.
  11. How to Replace a Corroded Car Battery Terminal: step 11, image 1 of 1
    • Place the negative terminal back onto the negative node.
  12. How to Replace a Corroded Car Battery Terminal: step 12, image 1 of 3 How to Replace a Corroded Car Battery Terminal: step 12, image 2 of 3 How to Replace a Corroded Car Battery Terminal: step 12, image 3 of 3
    • On the negative terminal, use the wrench to rotate the side nut clockwise to tighten it.
    • Next, perform the same action on the side nut of the positive terminal.
    • To ensure a secure connection, be sure the nut is snug and that the terminal can't come off easily.
Finish Line
17 other people completed this guide.
David Wright
655 Reputation
1 Guide authored
Cal Poly, Team 12-4, Green Winter 2015 Member of Cal Poly, Team 12-4, Green Winter 2015
CPSU-GREEN-W15S12G4
5 Members
9 Guides authored
8 Comments
Nice post. Shop car battery at batterybhai and their expert technical team come to install the battery with all battery replacement tools kit.
mayank tanwar - Reply
very interesting post. Thanks for sharing it.
https://www.sarexports.com/product-categ...
Raman Malik - Reply
I change negative terminal to new one still have corrosion why?
אנדריי מזילו - Reply
They are corrotion after doinging this within a4 to 5 month time the red cable is worst
Carol - Reply
Use Petroleum-Jelly (preferably) OR if not there then
use Vaseline onto both the Terminals( +, -ive) to prevent rusting of your both terminals of Battery PLEASE .
SANJAY KHANDELWAL -
Past 24 Hours: 22
Past 7 Days: 157
Past 30 Days: 716
All Time: 129,752
