How to Replace a Transition Strip (T Molding)
  1. How to Replace a Transition Strip (T Molding), Transition Strip (T Molding): step 1, image 1 of 1
    • Measure the exact width of the doorway using a tape measure.
  2. How to Replace a Transition Strip (T Molding): step 2, image 1 of 3 How to Replace a Transition Strip (T Molding): step 2, image 2 of 3 How to Replace a Transition Strip (T Molding): step 2, image 3 of 3
    • Mark the T molding based on the doorway measure.
    • Cut the T molding using a sharp saw (table saw).
    • Cutting the T molding can be done for free at the place of purchase.
    • If you don't have access to a sharp saw, cut the T molding using a jigsaw and use sanding paper to soften the end.
  3. How to Replace a Transition Strip (T Molding): step 3, image 1 of 3 How to Replace a Transition Strip (T Molding): step 3, image 2 of 3 How to Replace a Transition Strip (T Molding): step 3, image 3 of 3
    • Remove the old T molding.
    • You can use a pry bar to loosen the T molding.
  4. How to Replace a Transition Strip (T Molding): step 4, image 1 of 2 How to Replace a Transition Strip (T Molding): step 4, image 2 of 2
    • Use a utility knife to remove all the glue or any material used to keep the old T molding in place.
    • You may use a scraper instead of a utility knife.
    • Clean up the area thoroughly.
  5. How to Replace a Transition Strip (T Molding): step 5, image 1 of 1
    • Apply the glue evenly to the gap.
  6. How to Replace a Transition Strip (T Molding): step 6, image 1 of 3 How to Replace a Transition Strip (T Molding): step 6, image 2 of 3 How to Replace a Transition Strip (T Molding): step 6, image 3 of 3
    • Insert the T molding into the gap.
    • Press the T molding firmly onto the ground.
    • No gap should exist between the T molding and the floorings.
  7. How to Replace a Transition Strip (T Molding): step 7, image 1 of 2 How to Replace a Transition Strip (T Molding): step 7, image 2 of 2
    • Tape the T molding onto the floor.
    • This step ensures the T molding stays in place until the glue dries.
    • Wait 24 hours for the glue to dry.
    • Remove the tapes.
Rojean Noorinayer
145 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 6
Past 7 Days: 29
Past 30 Days: 150
All Time: 4,511
