How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard
  1. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard, How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: step 1, image 1 of 1
    • Unplug the computer from the power supply before disassembly.
    • Wait 5 minutes after the device has been powered off.
  2. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: step 2, image 1 of 3 How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: step 2, image 2 of 3 How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: step 2, image 3 of 3
    • Using a Phillips #1 screwdriver, remove two screws that would grant access to inner components of your computer.
    • Remove the side panel of the computer tower to access the inner components. Slide the panel then lift it to safely remove it.
    • Removing the panel may be different for your computer.
  3. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: step 3, image 1 of 3 How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: step 3, image 2 of 3 How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: step 3, image 3 of 3
    • Using the Phillips #1 screwdriver, remove the screw holding the graphics card (GPU) onto the motherboard.
    • Disconnect any power cables that may be attached to your graphics card.
    • Carefully slide the graphics card out from its slot.
  4. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: step 4, image 1 of 2 How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: step 4, image 2 of 2
    • Remove the CMOS Battery using a plastic opening tool.
    • There may be a spring mechanism available to use to easily remove the battery.
  5. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: step 5, image 1 of 1
    • Wait 5 minutes to allow enough time for the power to cycle through.
  6. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: step 6, image 1 of 1
    • Insert battery back into position with the flat side facing upwards.
2 other people completed this guide.
Andrew Barsoom
181 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 141
All Time: 4,453
