How to Use the Anti-Static Wrist Strap
  1. How to Use the Anti-Static Wrist Strap, Remove any jewelry: step 1, image 1 of 2 How to Use the Anti-Static Wrist Strap, Remove any jewelry: step 1, image 2 of 2
    • Before you begin, remove any jewelry from your wrist and fingers.
  2. How to Use the Anti-Static Wrist Strap, Adjust the strap: step 2, image 1 of 2 How to Use the Anti-Static Wrist Strap, Adjust the strap: step 2, image 2 of 2
    Tool used on this step:
    $7.95
    Buy
    • The anti-static strap should be adjusted to fit snugly on your wrist.
    • Pull up on the looped end of the strap to disengage the plastic lock.
  3. How to Use the Anti-Static Wrist Strap: step 3, image 1 of 2 How to Use the Anti-Static Wrist Strap: step 3, image 2 of 2
    • To tighten the strap, pull the looped end away from the plastic slide.
  4. How to Use the Anti-Static Wrist Strap: step 4, image 1 of 2 How to Use the Anti-Static Wrist Strap: step 4, image 2 of 2
    • To loosen the strap, pull the main part of the band away from the plastic slide.
    • Re-engage the plastic lock before continuing.
  5. How to Use the Anti-Static Wrist Strap: step 5, image 1 of 2 How to Use the Anti-Static Wrist Strap: step 5, image 2 of 2
    • Slide the strap over your hand and secure it to your wrist.
    • If the strap is still too loose or tight, you can adjust it while it's on your wrist.
  6. How to Use the Anti-Static Wrist Strap: step 6, image 1 of 2 How to Use the Anti-Static Wrist Strap: step 6, image 2 of 2
    • Attach the metal clip to one of the grounding nodes on an Anti-Static Mat or a grounded metal surface.
  7. How to Use the Anti-Static Wrist Strap: step 7, image 1 of 1
    • You're now ready to repair.
    • During your repair, be mindful of the strap's cable, as stretching it too far can cause the clip to unsnap.
For other general electronics skills guides, click here.
26 other people completed this guide.
Alex Diaz-Kokaisl
125,037 Reputation
582 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,430 Guides authored
4 Comments
J'ai un doute…
Retirer tout bijou/montre/whatever, mais uniquement sur la main où l'on met le bracelet (ce qui me paraît logique) ou bien des deux mains ?
Yacou - Reply
peut ton se connecter direct ex: sur une prise éléctrique avec l'embout terre de la prise
Lucka Lellig - Reply
Bonjour @luckalellig non, ceci est fortement déconseillé !! Le courant des prises électriques est trop fort et risquerait de vous électrocuter.
Claire Miesch -
non la terre pas ce branche au pole positif et négatif
Past 24 Hours: 34
Past 7 Days: 295
Past 30 Days: 1,364
All Time: 31,477
