Introduction
In this guide we show you, how to remove and replace the display assembly with frame in your Huawei P10 smartphone.
To protect your eyes from glass shreds and get a better grip to open the phone you might want to apply some tape onto the screen.
When reassembling apply new adhesive where it is necessary. Before reassembly check your new part for any components that might need to be transferred from the old one.
Switch off your phone.
Remove the two Pentalobe P2 screws at the bottom.
Remove the SIM card tray.
Peel out the adhesive strip which is placed beneath the battery by steadily pulling at the tab in a flat angle.
Use an iOpener to loosen the remaining adhesive.
Remove the four Phillips #00 screws.
Use tweezers to remove the metal plate that covers the charging board and the main flex cable.
Remove the vibration motor. If the adhesive is too strong, heat an iOpener to soften it and ease removal.
Use the flat end of a spudger to pry up under the speaker.
Remove the loudspeaker.
To reassemble your device, follow these instructions in reverse order. When reassembling apply new adhesive where it's necessary.
25 other people completed this guide.
5 Comments
Are the pink/purple blobs unter the motherboard thermal paste? If so, should I re-apply any when reassembling?
The answer might come to late, as you most likely finished the repair in the last 5 years, but it might still be useful for others:
Yes, the purple blobs under the mainboard are thermal paste.
If the paste is still soft you could potentially reuse it but I would highly recommend to use some new thermal paste.
Gonna upload an easy and faster way to do it whitout removibg the battery or upper boards and cameras, wait for it, my 1st guide.
I didn’t add the tape. I don’t know why the battery comes with it, plus, it is ultra strong, I was all the time afraid to ruin the battery, but fortunatly, everything went well
