MacBook Pro 15" Unibody Mid 2010 Lower Case Replacement
  1. MacBook Pro 15" Unibody Mid 2010 Lower Case Replacement, Lower Case: step 1, image 1 of 1
    • Three 13.5 mm (14.1 mm) Phillips screws.
    • Seven 3 mm Phillips screws.
    • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
  2. MacBook Pro 15" Unibody Mid 2010 Lower Case Replacement: step 2, image 1 of 1
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
46 other people completed this guide.
One Comment
When replacing the lower case, be sure to re-seat the clips that popped when removing it. There are two, located near the edge of the battery and the motherboard. Apply firm pressure over these spots until the clips click again, before replacing the screws.
keithbartholomew - Reply
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 28
All Time: 41,002
