Introduction
Upgrade your hard drive for more storage space! This guide will also show you how to replace the hard drive bracket.
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm (14.1 mm) Phillips screws.
Seven 3 mm Phillips screws.
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Remove two Phillips screws securing the hard drive bracket to the upper case.
Remove two T6 Torx screws from each side of the hard drive (four screws total).
If desired, peel the pull tab off your old hard drive and transfer it to the side of your new drive.
233 other people completed this guide.
31 Comments
This made me feel like techie instead of a newbie!
I have the MacBook Pro mid-2012 15" and I have installed Samsung SSD 840 EVO 2.5" form factor drive and it fits fine. Really makes the MacBook fast.
