Microsoft Surface Pro 4 Screen Adhesive Replacement
  1. Microsoft Surface Pro 4 Screen Adhesive Replacement, Remove the old adhesive: step 1, image 1 of 3 Microsoft Surface Pro 4 Screen Adhesive Replacement, Remove the old adhesive: step 1, image 2 of 3 Microsoft Surface Pro 4 Screen Adhesive Replacement, Remove the old adhesive: step 1, image 3 of 3
    • Scrape away all traces of adhesive and debris from the Surface's case and screen.
    • Use high concentration isopropyl alcohol (over 90%) or iFixit adhesive remover and a lint-free cloth to clean the adhesion surfaces on both the case and the screen.
    • If glue or glass remnants are left behind, the new screen will not mount correctly and may be damaged.
    • Lay the adhesive strips out to get an idea of where they go.
  2. Microsoft Surface Pro 4 Screen Adhesive Replacement, Apply the new adhesive: step 2, image 1 of 2 Microsoft Surface Pro 4 Screen Adhesive Replacement, Apply the new adhesive: step 2, image 2 of 2
    • Peel the white backing off of one adhesive strip, and carefully align it with the edge that matches the cutouts in the strip.
    • Lay the strip down lightly on its matching edge and make sure all the cutouts and edges of the strip line up with the Surface case.
    • Once aligned, use your fingers to press the adhesive strip down against the case.
    • Repeat this procedure for the remaining three adhesive strips.
  3. Microsoft Surface Pro 4 Screen Adhesive Replacement, Install the display: step 3, image 1 of 1
    • Continue reassembly until the cables are reconnected and you're ready to install the screen.
    • If possible, test your screen's functionality before sticking it in place.
    • Remove the clear backing from the adhesive strips.
    • Align the screen with the case and set it on top of the adhesive. Once it's aligned, press down on the edges of the screen to set the adhesive.
    • Apply a few books worth of weight on top of the screen for an hour to help the adhesive bond.
8 other people completed this guide.
Sam Omiotek
73,693 Reputation
288 Guides authored
0 Comments
Past 24 Hours: 7
Past 7 Days: 37
Past 30 Days: 181
All Time: 8,180
