Motorola Moto G5 Battery Replacement
  1. Motorola Moto G5 Battery Replacement, Back Cover: step 1, image 1 of 2 Motorola Moto G5 Battery Replacement, Back Cover: step 1, image 2 of 2
    • Insert your fingernail or the flat end of a spudger into the notch on the bottom edge of the phone near the charging port.
    • Pry with your fingernail or twist the spudger to release the back cover from the phone.
  2. Motorola Moto G5 Battery Replacement: step 2, image 1 of 3 Motorola Moto G5 Battery Replacement: step 2, image 2 of 3 Motorola Moto G5 Battery Replacement: step 2, image 3 of 3
    • Insert the flat end of a spudger into the seam and slide it along the bottom edge to release the clips holding the back cover to the phone.
  3. Motorola Moto G5 Battery Replacement: step 3, image 1 of 3 Motorola Moto G5 Battery Replacement: step 3, image 2 of 3 Motorola Moto G5 Battery Replacement: step 3, image 3 of 3
    • Continue sliding the flat end of the spudger along the seam for the remaining sides of the phone.
  4. Motorola Moto G5 Battery Replacement: step 4, image 1 of 2 Motorola Moto G5 Battery Replacement: step 4, image 2 of 2
    • Lift the back cover and remove it from the phone.
    • To reinstall the back cover, align the cover with the phone and squeeze along the edges to snap the clips back into place.
  5. Motorola Moto G5 Battery Replacement, Battery: step 5, image 1 of 2 Motorola Moto G5 Battery Replacement, Battery: step 5, image 2 of 2
    • Insert your fingernail or the flat end of the spudger into the notch below the battery.
    • Pry with your fingernail or spudger until you free the battery from its recess.
  6. Motorola Moto G5 Battery Replacement: step 6, image 1 of 1
    • Remove the battery.
    • When installing the battery, make sure the battery's contacts line up with the three gold pins on the top right.
After completing this guide, calibrate your newly-installed battery.
Repair didn’t go as planned? Check out our Motorola Moto G5 Answers community for troubleshooting help.
9 other people completed this guide.
Arthur Shi
252,736 Reputation
526 Guides authored
iFixit Member of iFixit
Staff
135 Members
16,817 Guides authored
5 Comments
this is not the g5 replacement procedure. it will not work.need to remove screen.
Tom Tercek - Reply
@Tom Tercek - You are in a huge mistake. This is the Motorola Moto G5 phone and the battery is removable and as shown on the pics, very easy to replace.
prishylets - Reply
is it also possible with moto g5s?
Jojo Blublub - Reply
Unfortunately, the G5S does not have an easily replaceable battery.
Arthur Shi -
Hi, I'm looking for parts for Moto G5, specifically an intern plastic cover that goes over the charge port.
Leonardo - Reply
Past 24 Hours: 12
Past 7 Days: 81
Past 30 Days: 448
All Time: 39,158
