This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Why! NH57ADS Keyboard Replacement
  1. Why! NH57ADS Keyboard Replacement, Battery: step 1, image 1 of 3 Why! NH57ADS Keyboard Replacement, Battery: step 1, image 2 of 3 Why! NH57ADS Keyboard Replacement, Battery: step 1, image 3 of 3
    • Remove the two screws holding the battery in place.
    • Slip your finger into the finger hole provided at the top of the battery and lift to remove it.
  2. Why! NH57ADS Keyboard Replacement, Bottom Cover: step 2, image 1 of 3 Why! NH57ADS Keyboard Replacement, Bottom Cover: step 2, image 2 of 3 Why! NH57ADS Keyboard Replacement, Bottom Cover: step 2, image 3 of 3
    • Remove the five Phillips screws securing the bottom to the case.
    • Slide the cover up slightly to release the catches holding it in place. This is the view on the right. The mark on the cover should now line up with the second mark on the case of the computer.
  3. Why! NH57ADS Keyboard Replacement, Removing the Bottom Cover: step 3, image 1 of 3 Why! NH57ADS Keyboard Replacement, Removing the Bottom Cover: step 3, image 2 of 3 Why! NH57ADS Keyboard Replacement, Removing the Bottom Cover: step 3, image 3 of 3
    • This is the view on the left before and after sliding the cover. The mark on the cover should now line up with the second mark on the case of the computer.
    • Lift the bottom cover to remove it.
  4. Why! NH57ADS Keyboard Replacement, Keyboard: step 4, image 1 of 3 Why! NH57ADS Keyboard Replacement, Keyboard: step 4, image 2 of 3 Why! NH57ADS Keyboard Replacement, Keyboard: step 4, image 3 of 3
    • Remove the two Phillips screws with the keypad symbol next to them.
    • Insert an opening pick into the upper slot of the keyboard and slide it to the end.
  5. Why! NH57ADS Keyboard Replacement, Remove the Keyboard: step 5, image 1 of 3 Why! NH57ADS Keyboard Replacement, Remove the Keyboard: step 5, image 2 of 3 Why! NH57ADS Keyboard Replacement, Remove the Keyboard: step 5, image 3 of 3
    • Carefully lift the keyboard.
    • Flip up the retaining latch on the black keyboard cable and slide it out of the connector.
    • Repeat with the orange backlight cable.
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
fr en
50%
Jerry Wheeler is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
31,100 Reputation
264 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 10
All Time: 118
