Nintendo Switch Lite Fan Replacement
  1. Nintendo Switch Lite Fan Replacement, Remove the back panel screws: step 1, image 1 of 1
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Before beginning this repair, make sure that the device is completely turned off.
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the back panel.
  2. Nintendo Switch Lite Fan Replacement, Remove the top and bottom back panel screws: step 2, image 1 of 2 Nintendo Switch Lite Fan Replacement, Remove the top and bottom back panel screws: step 2, image 2 of 2
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following screws securing the back panel:
    • Two 3.6 mm-long screws on the top of the device
    • Two 3.6 mm-long screws on the bottom of the device
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try a different screwdriver if the screws won't come out.
  3. Nintendo Switch Lite Fan Replacement, Release the clips securing the back panel: step 3, image 1 of 2 Nintendo Switch Lite Fan Replacement, Release the clips securing the back panel: step 3, image 2 of 2
    • Insert an opening tool into the left speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips securing the back panel.
    • Avoid inserting the opening tool further than required to prevent damage to the speaker module.
  4. Nintendo Switch Lite Fan Replacement, Continue releasing the clips around the device: step 4, image 1 of 2 Nintendo Switch Lite Fan Replacement, Continue releasing the clips around the device: step 4, image 2 of 2
    • Slide the opening tool around the bottom-left corner to release the clips on the left side of the device.
  5. Nintendo Switch Lite Fan Replacement, Twist to release the clips: step 5, image 1 of 2 Nintendo Switch Lite Fan Replacement, Twist to release the clips: step 5, image 2 of 2
    • Insert an opening tool into the right speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips.
  6. Nintendo Switch Lite Fan Replacement, Slide and pry around the corners: step 6, image 1 of 2 Nintendo Switch Lite Fan Replacement, Slide and pry around the corners: step 6, image 2 of 2
    • Slide and pry the opening tool around the bottom-right corner to release the clips on the right side of the device.
  7. Nintendo Switch Lite Fan Replacement: step 7, image 1 of 2 Nintendo Switch Lite Fan Replacement: step 7, image 2 of 2
    • Continue sliding and prying the opening tool along the gap on the top of the device to release the clips.
  8. Nintendo Switch Lite Fan Replacement, Remove the back panel: step 8, image 1 of 3 Nintendo Switch Lite Fan Replacement, Remove the back panel: step 8, image 2 of 3 Nintendo Switch Lite Fan Replacement, Remove the back panel: step 8, image 3 of 3
    • Lift the bottom edge of the back panel, opening it like a book.
    • Remove the back panel.
  9. Nintendo Switch Lite Fan Replacement, Remove the shield plate: step 9, image 1 of 1
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following four screws:
    • Three 3.1 mm screws
    • One 4.5 mm screw
  10. Nintendo Switch Lite Fan Replacement: step 10, image 1 of 3 Nintendo Switch Lite Fan Replacement: step 10, image 2 of 3 Nintendo Switch Lite Fan Replacement: step 10, image 3 of 3
    • Use a spudger or your fingers to lift the shield plate up and out of the device.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • Remove the shield plate.
    • Clean off the old thermal paste from the shield plate and heat sink using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the heat sink before reassembly.
  11. Nintendo Switch Lite Fan Replacement, Disconnect the battery: step 11, image 1 of 2 Nintendo Switch Lite Fan Replacement, Disconnect the battery: step 11, image 2 of 2
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the motherboard interconnect cable's ZIF connector.
  12. Nintendo Switch Lite Fan Replacement: step 12, image 1 of 2 Nintendo Switch Lite Fan Replacement: step 12, image 2 of 2
    Buy
    • Do Not Use Metal Tweezers! Some fixers state that metallic tweezers can short circuit the ribbon cable/connector. It might be safer to just use nylon-tipped or ceramic-tipped tweezers.
    • Use a pair of tweezers to slide the interconnect cable out of its connector on the motherboard.
  13. Nintendo Switch Lite Fan Replacement: step 13, image 1 of 2 Nintendo Switch Lite Fan Replacement: step 13, image 2 of 2
    • Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
  14. Nintendo Switch Lite Fan Replacement, Remove the heat sink: step 14, image 1 of 1
    • Use the flat end of a spudger or your fingers to carefully peel up the foam that's lightly adhered to the fan.
    • The foam only needs to be peeled back enough to clear the fan.
  15. Nintendo Switch Lite Fan Replacement: step 15, image 1 of 1
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the three 3 mm screws securing the heat sink to the motherboard.
  16. Nintendo Switch Lite Fan Replacement: step 16, image 1 of 3 Nintendo Switch Lite Fan Replacement: step 16, image 2 of 3 Nintendo Switch Lite Fan Replacement: step 16, image 3 of 3
    • Use a spudger or your fingers to lift the heatsink up and off of the motherboard to remove it.
    • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste.
    • Clean off the old thermal paste from the heat sink and CPU using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly.
  17. Nintendo Switch Lite Fan Replacement, Remove the fan: step 17, image 1 of 2 Nintendo Switch Lite Fan Replacement, Remove the fan: step 17, image 2 of 2
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the fan cable's ZIF connector.
  18. Nintendo Switch Lite Fan Replacement: step 18, image 1 of 2 Nintendo Switch Lite Fan Replacement: step 18, image 2 of 2
    Buy
    • Use a pair of tweezers to slide out the fan cable from its connector on the motherboard.
  19. Nintendo Switch Lite Fan Replacement: step 19, image 1 of 1
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the three 4.8 mm screws securing the fan.
  20. Nintendo Switch Lite Fan Replacement: step 20, image 1 of 3 Nintendo Switch Lite Fan Replacement: step 20, image 2 of 3 Nintendo Switch Lite Fan Replacement: step 20, image 3 of 3
    • Remove the fan.
    • Take care not to snag the fan cable on the motherboard as you remove the fan.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Lite Answers community for help.
5 other people completed this guide.
Craig Lloyd
35,673 Reputation
82 Guides authored
One Comment
I used this guide to put my new fan in and let me just say THANK YOU!!! All I could find was ones for regular Switches on YouTube and not the Lite. The only problem I had was I'm not sure which side of the cable on the fan should be facing up. I looked on your website and the fan listen on here has one side with a gold part at the end where you insert it into the connector. Is that the side that goes up?
Skylar Neville - Reply
Past 24 Hours: 20
Past 7 Days: 103
Past 30 Days: 403
All Time: 13,364
