This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Sparks plugs and/or ignition coils replacement
  1. Sparks plugs and/or ignition coils replacement, Accessing the engine hood: step 1, image 1 of 1
    • Open the trunk.
    • Put aside the trunk carpets.
  2. Sparks plugs and/or ignition coils replacement, Acessing the engine compartment: step 2, image 1 of 1
    • Unscrew the 6 T50 screws by hand or using a wrench and a socket.
    • Lift and put aside the engine hood.
  3. Sparks plugs and/or ignition coils replacement, Extracting ignition coils: step 3, image 1 of 3 Sparks plugs and/or ignition coils replacement, Extracting ignition coils: step 3, image 2 of 3 Sparks plugs and/or ignition coils replacement, Extracting ignition coils: step 3, image 3 of 3
    • Disconnect and put aside the oil vapors duct.
    • Disconnect the ignition coils' connector.
    • Unscrew each 8mm bolts of the 3 ignition coils.
    • Gently extract the ignition coils.
  4. Sparks plugs and/or ignition coils replacement, Extracting the spark plugs: step 4, image 1 of 2 Sparks plugs and/or ignition coils replacement, Extracting the spark plugs: step 4, image 2 of 2
    • Unscrew and extract the spark plugs using a 14mm spark plug socket.
    • Clean off and/or dust off the debris in the zone to avoid contamination in the cylinders.
    • The Nickel/Copper spark plug shown aside is around 25.000km aged, using 100% E85.
  5. Sparks plugs and/or ignition coils replacement, Installating the new spark plugs: step 5, image 1 of 1
    • Torque the new spark plug using a 14mm spark plug socket at 24 N.m.
    • Verify and ajust the spark plug gap to the considered model's spec if necessary.
    • The RTA (French Revue Technique Automobile) and spark plug manufacturers advise not to grease the spark plug's thread.
    • Do not modify an used spark plug's gap.
  6. Sparks plugs and/or ignition coils replacement, Reinstalling the ignition coils: step 6, image 1 of 2 Sparks plugs and/or ignition coils replacement, Reinstalling the ignition coils: step 6, image 2 of 2
    • Put back the ignition coils on the spark plugs.
    • Torque each of the 3 ignition coils' 8mm bolts at 10 N.m.
    • Reconnect the ignition coil's connectors.
Congratulations ! You replaced you spark plugs/ignition coils !
4 other people completed this guide.
Special thanks to these translators:
fr en
57%
AntonioBiscuit is helping us fix the world! Want to contribute?
Start translating ›
AntonioBiscuit
5,728 Reputation
40 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 32
Past 30 Days: 124
All Time: 2,221
