Safely remove PC case stickers
  1. Safely remove PC case stickers, Remove the battery (Laptops only): step 1, image 1 of 2 Safely remove PC case stickers, Remove the battery (Laptops only): step 1, image 2 of 2
    • The procedure to remove the battery is specific to every laptop.
    • Before removing the stickers, remove the battery.
  2. Safely remove PC case stickers, Warm up the adhesive: step 2, image 1 of 3 Safely remove PC case stickers, Warm up the adhesive: step 2, image 2 of 3 Safely remove PC case stickers, Warm up the adhesive: step 2, image 3 of 3
    Tool used on this step:
    iFixit Opening Picks (Set of 6)
    Buy
    • 30-60 seconds of heat is sufficient.
    • If the sticker is thin, a guitar pick may help.
    • After removing the battery, warm up the palmrest with a hairdryer until it is warm to the touch.
    • Peel the stickers off.
  3. Safely remove PC case stickers, Clean the remaining glue: step 3, image 1 of 3 Safely remove PC case stickers, Clean the remaining glue: step 3, image 2 of 3 Safely remove PC case stickers, Clean the remaining glue: step 3, image 3 of 3
    • While denatured alchol works, it may "strip" some rubber coatings and paint! Use good judgement!
    • After the sticker(s) have been removed, clean the residual glue with a small amount of gentle solvent.
    • Clean the solvent after a few seconds.
Finish Line
6 other people completed this guide.
Nick
89,092 Reputation
50 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,487 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 143
All Time: 15,820
