Samsung Galaxy S5 Mini Battery Replacement
  1. Samsung Galaxy S5 Mini Battery Replacement, Rear Panel: step 1, image 1 of 3 Samsung Galaxy S5 Mini Battery Replacement, Rear Panel: step 1, image 2 of 3 Samsung Galaxy S5 Mini Battery Replacement, Rear Panel: step 1, image 3 of 3
    • Insert a fingernail or a plastic opening tool into the slot located above the power button.
    • Gently pull the panel off the back of the phone.
    • The plastic snaps will make a popping sound as they separate.
  2. Samsung Galaxy S5 Mini Battery Replacement, Battery: step 2, image 1 of 3 Samsung Galaxy S5 Mini Battery Replacement, Battery: step 2, image 2 of 3 Samsung Galaxy S5 Mini Battery Replacement, Battery: step 2, image 3 of 3
    • Insert fingernail or plastic opening tool into the slot at the bottom of the battery.
    • Gently pry the battery away from the phone.
    • When replacing the battery, ensure the contacts are aligned and press lightly. The battery will appear to fit in multiple directions, so do not force it in.
7 other people completed this guide.
Ethan Juhnke
162 Reputation
1 Guide authored
Cal Poly, Team 12-4, Forte Fall 2014 Member of Cal Poly, Team 12-4, Forte Fall 2014
CPSU-FORTE-F14S12G4
5 Members
38 Guides authored
2 Comments
that was so so hard!
dennysb de - Reply
But battery not charging properly
kapil jadhav - Reply
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 33
All Time: 10,229
