This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Introduction
This is the procedure for replacing the keyboard on a VAIO Pro PF (VJPF11*)
The bottom and key-top components can be separated by removing the rear screws.
Pull out the flat cable shown in the picture to completely decouple it.
Use a spatula to separate the plastic pins that hold the keyboard top and keyboard in place.
A portion of the broken pin will remain, and the new keyboard will be glued to this to hold it in place.
The left side is the new keyboard and the right side is the old keyboard.
Install the new keyboard, fitting the plastic pins for the remaining fixation.
An adhesive is used to secure the keyboard. In this case, UV cured glue is used. For stronger fixation, epoxy glue should be used.
Install all cover seals and FAN airflow seals that were used for insulation.
Tie the flat cable and secure the keyboard top and mainboard side with screws.
Turn on the power and check that the key input and backlight work properly.
Thank you for your hard work!
Special thanks to these translators:
81%
Satoshi Imaizumi is helping us fix the world! Want to contribute?
Start translating ›
