Wall Outlet Cover Replacement
  1. Wall Outlet Cover Replacement, Wall Outlet Cover: step 1, image 1 of 3 Wall Outlet Cover Replacement, Wall Outlet Cover: step 1, image 2 of 3 Wall Outlet Cover Replacement, Wall Outlet Cover: step 1, image 3 of 3
    • Remove any hazardous pieces from previous cover.
    • Be sure to remove the two flathead screws to remove any debris, rather than trying to pull off the sharp pieces.
  2. Wall Outlet Cover Replacement: step 2, image 1 of 3 Wall Outlet Cover Replacement: step 2, image 2 of 3 Wall Outlet Cover Replacement: step 2, image 3 of 3
    • Insert any cable or cables that may be hanging out inside of the wall hole.
    • Making a loop in the cable might be helpful to push it inside the wall.
  3. Wall Outlet Cover Replacement: step 3, image 1 of 1
    • Insert two screws into the holes of the new wall cover.
  4. Wall Outlet Cover Replacement: step 4, image 1 of 3 Wall Outlet Cover Replacement: step 4, image 2 of 3 Wall Outlet Cover Replacement: step 4, image 3 of 3
    • Line up the screws in the plate with the screw holes in the wall.
    • Tighten the screws slightly with your hands to ensure that both screws have found the proper holes.
    • Once the screws have been tightened enough to stay in the holes, they should hold the outlet cover in place.
  5. Wall Outlet Cover Replacement: step 5, image 1 of 3 Wall Outlet Cover Replacement: step 5, image 2 of 3 Wall Outlet Cover Replacement: step 5, image 3 of 3
    • Tighten the two screws with a flathead screwdriver.
  6. Wall Outlet Cover Replacement: step 6, image 1 of 3 Wall Outlet Cover Replacement: step 6, image 2 of 3 Wall Outlet Cover Replacement: step 6, image 3 of 3
    • Double check that the wall cover plate does not have a gap, and it is completely attached to the wall.
    • If any gap is detected, push the plate to the wall and continue to tighten the screws until the gap completely closes.
Leydi Navarrete
133 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 55
All Time: 1,107
