Water Filtration System Filter Replacement
  1. Water Filtration System Filter Replacement, Filter: step 1, image 1 of 2 Water Filtration System Filter Replacement, Filter: step 1, image 2 of 2
    • Turn off water supply.
  2. Water Filtration System Filter Replacement: step 2, image 1 of 1
    • Press the button on the top of the filtration device to release water pressure and let excess water drain.
  3. Water Filtration System Filter Replacement: step 3, image 1 of 2 Water Filtration System Filter Replacement: step 3, image 2 of 2
    • Unscrew the filter canister using the canister wrench.
  4. Water Filtration System Filter Replacement: step 4, image 1 of 2 Water Filtration System Filter Replacement: step 4, image 2 of 2
    • Take out the old filter and discard it.
  5. Water Filtration System Filter Replacement: step 5, image 1 of 1
    • Clean out the inside of the filter canister with soap and water.
  6. Water Filtration System Filter Replacement: step 6, image 1 of 1
    • Put the new filter inside the filter canister, making sure it goes in properly.
  7. Water Filtration System Filter Replacement: step 7, image 1 of 3 Water Filtration System Filter Replacement: step 7, image 2 of 3 Water Filtration System Filter Replacement: step 7, image 3 of 3
    • Screw the filter canister back into place using the canister wrench, making sure it's tightly screwed in.
  8. Water Filtration System Filter Replacement: step 8, image 1 of 2 Water Filtration System Filter Replacement: step 8, image 2 of 2
    • Turn the water supply back on.
  9. Water Filtration System Filter Replacement: step 9, image 1 of 1
    • Press the button on the top of the device to release any air trapped inside.
You have now successfully replaced your water filter.
2 other people completed this guide.
Tahj Ramirez
223 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 109
All Time: 1,867
