Xbox One Wireless Controller 1697 Rumble Motor Replacement
  1. Xbox One Wireless Controller 1697 Rumble Motor Replacement, Bumpers: step 1, image 1 of 1
    • Remove the battery pack cover.
    • Remove the two AA batteries.
    • Carefully remove the sticker or puncture to reveal the screw.
  2. Xbox One Wireless Controller 1697 Rumble Motor Replacement: step 2, image 1 of 3 Xbox One Wireless Controller 1697 Rumble Motor Replacement: step 2, image 2 of 3 Xbox One Wireless Controller 1697 Rumble Motor Replacement: step 2, image 3 of 3
    • Remove the side handles by wedging the spudger around the side panels.
    • Pry the side panel by moving the spudger back and forth. You must do this along the entire seam to remove the side handle panel.
    • There are seven clips that need to be opened to remove each handle panel.
  3. Xbox One Wireless Controller 1697 Rumble Motor Replacement: step 3, image 1 of 3 Xbox One Wireless Controller 1697 Rumble Motor Replacement: step 3, image 2 of 3 Xbox One Wireless Controller 1697 Rumble Motor Replacement: step 3, image 3 of 3
    • Removing the side handles allows access to remove the faceplate.
    • Use the TORX TR8 screwdriver to remove the five TR9 Torx screws.
  4. Xbox One Wireless Controller 1697 Rumble Motor Replacement: step 4, image 1 of 3 Xbox One Wireless Controller 1697 Rumble Motor Replacement: step 4, image 2 of 3 Xbox One Wireless Controller 1697 Rumble Motor Replacement: step 4, image 3 of 3
    • Now that the bumpers are easily visible make sure to clean any dirt or grime that may be around the bumpers.
    • The bumpers are connected by a middle plastic cover that is around the Xbox home button. Remove this plastic piece by lifting the plastic cover over the two pins, pressing the home button in, and pushing the cover towards the top of the controller.
    • Be aware of the sync button loosely placed under the plastic covering. Ensure it is put back before putting back the bumper/plastic cover assembly.
    • Remove the current bumper assembly by pulling them off the plastic cover.
  5. Xbox One Wireless Controller 1697 Rumble Motor Replacement: step 5, image 1 of 3 Xbox One Wireless Controller 1697 Rumble Motor Replacement: step 5, image 2 of 3 Xbox One Wireless Controller 1697 Rumble Motor Replacement: step 5, image 3 of 3
    • The controller is now ready for the new bumper assembly.
    • Align the new bumpers onto the top of the controller by holding down the triggers and aligning the four pins on both sides.
    • Set the new home button cover over the micro USB port, push the home button in, and pull the cover over the two pins shown.
  6. Xbox One Wireless Controller 1697 Rumble Motor Replacement, Rumble Motor: step 6, image 1 of 2 Xbox One Wireless Controller 1697 Rumble Motor Replacement, Rumble Motor: step 6, image 2 of 2
    • De-solder the soldered joints while holding the red and black wires down on the top motherboard.
    • Use the How to Solder and Desolder Connections guide on iFixit to correctly (de)solder the components in your device.
    • Use caution while using the soldering iron so you don't damage other components or hurt yourself.
  7. Xbox One Wireless Controller 1697 Rumble Motor Replacement: step 7, image 1 of 1
    • Remove the rumble motors.
6 other people completed this guide.
Ryan Burroughs
1,172 Reputation
2 Guides authored
USF Tampa, Team S9-G1, Remmell Fall 2017 Member of USF Tampa, Team S9-G1, Remmell Fall 2017
USFT-REMMELL-F17S9G1
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 7
Past 7 Days: 24
Past 30 Days: 77
All Time: 8,480
