Xbox One Wireless Controller D-Pad Replacement
  1. Xbox One Wireless Controller D-Pad Replacement, Battery Pack: step 1, image 1 of 1
    • Remove the battery pack cover.
    • Remove batteries.
  2. Xbox One Wireless Controller D-Pad Replacement, Side Handles: step 2, image 1 of 2 Xbox One Wireless Controller D-Pad Replacement, Side Handles: step 2, image 2 of 2
    • We recommend using a nylon spudger for this step. A metal spudger is shown.
    • Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
    • Pry the side plate away from the front plate by moving the spudger back and forth. You will need to do this all the way around the side plate's seam.
  3. Xbox One Wireless Controller D-Pad Replacement, Screws: step 3, image 1 of 2 Xbox One Wireless Controller D-Pad Replacement, Screws: step 3, image 2 of 2
    • There is a hidden screw located in the middle of the controller behind the label.
    • Use a screwdriver and punch a hole directly in the center of the label.
    • You may also lift the label if you do not want to puncture it.
    • Remove the five 10mm screws located on the back of the controller using the TR8 Security Torx Screwdriver.
  4. Xbox One Wireless Controller D-Pad Replacement, Backplate: step 4, image 1 of 1
    • Remove the backplate.
  5. Xbox One Wireless Controller D-Pad Replacement, Faceplate: step 5, image 1 of 1
    • Remove the faceplate.
  6. Xbox One Wireless Controller D-Pad Replacement, Metal Frame: step 6, image 1 of 2 Xbox One Wireless Controller D-Pad Replacement, Metal Frame: step 6, image 2 of 2
    • Pry off the metal frame around the D-Pad.
  7. Xbox One Wireless Controller D-Pad Replacement, D-Pad: step 7, image 1 of 1
    • Lift the D-Pad out of its housing.
44 other people completed this guide.
Garrett George
6,154 Reputation
3 Guides authored
Cal Poly, Team 20-15, Maness Winter 2015 Member of Cal Poly, Team 20-15, Maness Winter 2015
CPSU-MANESS-W15S20G15
5 Members
50 Guides authored
7 Comments
Can you show me how to replace xbox one controller 3.5mm stereo jack dpad
Arief Hidayat - Reply
This model of the xbox one controller does not feature a 3.5mm headphone jack. Please look at the guides for later models of the xbox one controller.
Brandon -
it's exactly the same like shown above :)
David Schmidt - Reply
How do u fix one of the silver things behind the d-pad?
Bob - Reply
How do fix the silver things behind each d-pad
Bob - Reply
Past 24 Hours: 14
Past 7 Days: 88
Past 30 Days: 309
All Time: 63,407
