iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement
  1. iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement, M.2 NVMe Drive: step 1, image 1 of 2 iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement, M.2 NVMe Drive: step 1, image 2 of 2
    • Lay the desktop on its side with the glass panel facing up.
    • Remove the single screw.
  2. iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement: step 2, image 1 of 2 iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement: step 2, image 2 of 2
    • Remove the glass side by pivoting it up with the bottom side still seated in the notches.
    • Lift the glass side out of the notches and set it to the side.
  3. iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement: step 3, image 1 of 3 iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement: step 3, image 2 of 3 iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement: step 3, image 3 of 3
    • Locate the M.2 drive that is right above the CPU.
    • Remove the screw on the edge of the drive.
  4. iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement: step 4, image 1 of 2 iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement: step 4, image 2 of 2
    • The drive should lift up on the edge where the screw was.
    • Pull the drive out at an angle from the motherboard.
  5. iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement: step 5, image 1 of 2 iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement: step 5, image 2 of 2
    • Line the new drive up with the slot and gently slide it in.
    • Use one finger to hold the drive down while you screw it back in.
2 other people completed this guide.
One Comment
Thank you, Kilie, for the clear step-by-step instructions, together with pictures, for NVMe SSD installation.
George
George Meier - Reply
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 111
All Time: 2,648
