iPad 2 Wi-Fi EMC 2560 Front Panel Adhesive Strips Replacement
  1. iPad 2 Wi-Fi EMC 2560 Front Panel Adhesive Strips Replacement, Home Button: step 1, image 1 of 3 iPad 2 Wi-Fi EMC 2560 Front Panel Adhesive Strips Replacement, Home Button: step 1, image 2 of 3 iPad 2 Wi-Fi EMC 2560 Front Panel Adhesive Strips Replacement, Home Button: step 1, image 3 of 3
    • Carefully grasp the home button with a pair of tweezers.
    • Gently lower and place the home button into the round opening located at the bottom of the front panel.
    • The correct orientation of the home button is shown in the third picture. Make sure the back of the home button is face up and the flat portion of the inner home button circle is oriented to the top of the iPad.
  2. iPad 2 Wi-Fi EMC 2560 Front Panel Adhesive Strips Replacement, Front Panel Adhesive Strips: step 2, image 1 of 2 iPad 2 Wi-Fi EMC 2560 Front Panel Adhesive Strips Replacement, Front Panel Adhesive Strips: step 2, image 2 of 2
    • The two small notched trapezoidal strips will be used to attach the home button bracket to the front panel.
    • Carefully peel off the first trapezoidal adhesive strip.
  3. iPad 2 Wi-Fi EMC 2560 Front Panel Adhesive Strips Replacement: step 3, image 1 of 2 iPad 2 Wi-Fi EMC 2560 Front Panel Adhesive Strips Replacement: step 3, image 2 of 2
    • Using a pair of tweezers, place the first trapezoidal adhesive strip (minding its correct orientation) on the matching side of the home button mounting bracket.
    • Make sure to line up the profile of the strip with the edge of the mounting bracket.
    • Repeat the procedure for the second trapezoidal adhesive strip.
  4. iPad 2 Wi-Fi EMC 2560 Front Panel Adhesive Strips Replacement: step 4, image 1 of 1
    • Use a pair of tweezers to grasp the corner of one of the adhesive strips placed on the mounting bracket.
    • Lift and peel the brown backing up off the adhesive strip, revealing the clear adhesive strip.
    • Repeat the procedure for the secondary adhesive strip.
  5. iPad 2 Wi-Fi EMC 2560 Front Panel Adhesive Strips Replacement: step 5, image 1 of 2 iPad 2 Wi-Fi EMC 2560 Front Panel Adhesive Strips Replacement: step 5, image 2 of 2
    • Gently place the home button mounting bracket on top of the home button.
    • Make sure the home button mounting bracket is lined up with the bottom of the digitizer.
  6. iPad 2 Wi-Fi EMC 2560 Front Panel Adhesive Strips Replacement: step 6, image 1 of 2 iPad 2 Wi-Fi EMC 2560 Front Panel Adhesive Strips Replacement: step 6, image 2 of 2
    • In the following steps, you will be placing the remaining pieces of adhesive on the front panel.
    • Do not peel the brown backing off the strips just yet.
    • Place the largest L-shaped adhesive strip on the top left corner of the front panel.
    • Smooth the strip down from the center out, taking care to not trap any air bubbles between the strip and the front panel.
  7. iPad 2 Wi-Fi EMC 2560 Front Panel Adhesive Strips Replacement: step 7, image 1 of 2 iPad 2 Wi-Fi EMC 2560 Front Panel Adhesive Strips Replacement: step 7, image 2 of 2
    • Place the thinnest L-shaped adhesive strip on the bottom left corner of the front panel.
  8. iPad 2 Wi-Fi EMC 2560 Front Panel Adhesive Strips Replacement: step 8, image 1 of 2 iPad 2 Wi-Fi EMC 2560 Front Panel Adhesive Strips Replacement: step 8, image 2 of 2
    • Place the remaining thin L-shaped adhesive strip on the top right corner of the front panel, near the camera mounting bracket.
  9. iPad 2 Wi-Fi EMC 2560 Front Panel Adhesive Strips Replacement: step 9, image 1 of 2 iPad 2 Wi-Fi EMC 2560 Front Panel Adhesive Strips Replacement: step 9, image 2 of 2
    • Place the straight adhesive strip on the right side of the front panel.
    • If you've already attached the digitizer cable, you'll have to work around/under it to attach this strip.
  10. iPad 2 Wi-Fi EMC 2560 Front Panel Adhesive Strips Replacement: step 10, image 1 of 2 iPad 2 Wi-Fi EMC 2560 Front Panel Adhesive Strips Replacement: step 10, image 2 of 2
    • Place the last L-shaped adhesive strip on the bottom right corner of the front panel.
  11. iPad 2 Wi-Fi EMC 2560 Front Panel Adhesive Strips Replacement: step 11, image 1 of 2 iPad 2 Wi-Fi EMC 2560 Front Panel Adhesive Strips Replacement: step 11, image 2 of 2
    • Lay the thin T-shaped adhesive strip between the bottom edge of the inner frame of the front panel and the camera mounting bracket. The longest edge should be flush with the inner frame.
  12. iPad 2 Wi-Fi EMC 2560 Front Panel Adhesive Strips Replacement: step 12, image 1 of 2 iPad 2 Wi-Fi EMC 2560 Front Panel Adhesive Strips Replacement: step 12, image 2 of 2
    • Place the small hook-shaped adhesive strip below the left side of the home button mounting bracket.
  13. iPad 2 Wi-Fi EMC 2560 Front Panel Adhesive Strips Replacement: step 13, image 1 of 2 iPad 2 Wi-Fi EMC 2560 Front Panel Adhesive Strips Replacement: step 13, image 2 of 2
    • Lay the final small rectangular adhesive strip to the left of the hook-shaped adhesive strip, immediately to the right of the thin L-shaped strip, and flush with the bottom of the front panel.
  14. iPad 2 Wi-Fi EMC 2560 Front Panel Adhesive Strips Replacement: step 14, image 1 of 2 iPad 2 Wi-Fi EMC 2560 Front Panel Adhesive Strips Replacement: step 14, image 2 of 2
    • Make sure that each adhesive strip is placed in the correct location and orientation before peeling the backing.
    • Peel the brown backing up off each adhesive strip.
    • Some of the adhesive strips are quite small and may require some patience to peel the backing.
Finish Line
24 other people completed this guide.
Sam Goldheart
465,810 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,125 Guides authored
One Comment
Unfortunately, as of my order shipped on 5/30/2019, this guide is obsolete. The new strips are in clear semi-rigid carrier, with transparent blue backing, The new adhesive strips:
There are now only four strips of adhesive, die cut to different shapes which are completely unlike those shown in this guide - two long, unwieldy strips that run the full length of each side and wrap partway onto the top & bottom, a third strip that wraps around the front-facing camera at the top (with no applicable instructions I put it on backward so it doesn’t fit the side strips), and a fourth little bitty strip  with a half-arrowhead, about 5/8”/17mm long, that doesn’t come close to filling the 1-1/2”/4 cm gap between the home button and the right-side strip, but I stuck it on anyway,
As a result, these instructions are no longer relevant. Sorry Sam’s great effort is no longer useful.
scottmillett - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 13
All Time: 8,023
