iPhone 13 Battery Replacement
  1. iPhone 13 Battery Replacement, Remove the pentalobe screws: step 1, image 1 of 1
    • Caution: Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.8 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 13 Battery Replacement, Mark your opening picks: step 2, image 1 of 3 iPhone 13 Battery Replacement, Mark your opening picks: step 2, image 2 of 3 iPhone 13 Battery Replacement, Mark your opening picks: step 2, image 3 of 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  3. iPhone 13 Battery Replacement, Tape over any cracks: step 3, image 1 of 3 iPhone 13 Battery Replacement, Tape over any cracks: step 3, image 2 of 3 iPhone 13 Battery Replacement, Tape over any cracks: step 3, image 3 of 3
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  4. iPhone 13 Battery Replacement, Anti-Clamp instructions: step 4, image 1 of 3 iPhone 13 Battery Replacement, Anti-Clamp instructions: step 4, image 2 of 3 iPhone 13 Battery Replacement, Anti-Clamp instructions: step 4, image 3 of 3
    Tool used on this step:
    Anti-Clamp
    $24.95
    Buy
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone 13 Battery Replacement: step 5, image 1 of 3 iPhone 13 Battery Replacement: step 5, image 2 of 3 iPhone 13 Battery Replacement: step 5, image 3 of 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone 13 Battery Replacement: step 6, image 1 of 2 iPhone 13 Battery Replacement: step 6, image 2 of 2
    • Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
    • Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen's plastic bezel when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  7. iPhone 13 Battery Replacement, Heat the bottom edge: step 7, image 1 of 1
    • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
    • Never leave your hair dryer in one spot for an extended period of time.
  8. iPhone 13 Battery Replacement, Apply a suction cup: step 8, image 1 of 2 iPhone 13 Battery Replacement, Apply a suction cup: step 8, image 2 of 2
    • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the very edge of the glass.
  9. iPhone 13 Battery Replacement, Lift the screen slightly: step 9, image 1 of 3 iPhone 13 Battery Replacement, Lift the screen slightly: step 9, image 2 of 3 iPhone 13 Battery Replacement, Lift the screen slightly: step 9, image 3 of 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • Insert an opening pick into the gap under the screen's plastic bezel.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  10. iPhone 13 Battery Replacement, Heat the right edge: step 10, image 1 of 2 iPhone 13 Battery Replacement, Heat the right edge: step 10, image 2 of 2
    • Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) for 90 seconds or until the screen is slightly too hot to touch.
  11. iPhone 13 Battery Replacement, Separate the right adhesive: step 11, image 1 of 3 iPhone 13 Battery Replacement, Separate the right adhesive: step 11, image 2 of 3 iPhone 13 Battery Replacement, Separate the right adhesive: step 11, image 3 of 3
    • Slide the opening pick around the bottom right corner of the iPhone to separate its adhesive.
    • Continue sliding up the right edge of the iPhone until you reach the top right corner.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
    • Leave the pick in the top right corner before continuing.
  12. iPhone 13 Battery Replacement: step 12, image 1 of 1
    • Use a hair dryer to heat the top edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
  13. iPhone 13 Battery Replacement: step 13, image 1 of 3 iPhone 13 Battery Replacement: step 13, image 2 of 3 iPhone 13 Battery Replacement: step 13, image 3 of 3
    • Slide the opening pick around the top right corner of the iPhone to separate the top adhesive.
    • Don't insert your pick more than 3 mm, as you may the top sensors.
    • Leave the pick in the top left corner before continuing.
  14. iPhone 13 Battery Replacement, Heat the left edge: step 14, image 1 of 2 iPhone 13 Battery Replacement, Heat the left edge: step 14, image 2 of 2
    • Use a hair dryer to heat the left edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
  15. iPhone 13 Battery Replacement, Screen information: step 15, image 1 of 1
    • There are delicate cables along the left edge of your iPhone. Don't insert your pick here, as you may damage the cables.
  16. iPhone 13 Battery Replacement, Separate the left adhesive: step 16, image 1 of 2 iPhone 13 Battery Replacement, Separate the left adhesive: step 16, image 2 of 2
    • Insert a second opening pick in the bottom left corner of the iPhone.
    • Twist both picks simultaneously until the left edge clips release.
    • Apply the twisting force gradually.
    • If you're having trouble separating the adhesive, reheat the left edge.
  17. iPhone 13 Battery Replacement, Open the iPhone: step 17, image 1 of 3 iPhone 13 Battery Replacement, Open the iPhone: step 17, image 2 of 3 iPhone 13 Battery Replacement, Open the iPhone: step 17, image 3 of 3
    • If you haven't removed your suction handle, remove it now.
    • Rotate your iPhone so the right edge faces you.
    • Open the iPhone by swinging the display up from the right side, like the front cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
  18. iPhone 13 Battery Replacement, Unscrew the battery and display connector cover: step 18, image 1 of 1
    Magnetic Project Mat
    $19.95
    Buy
    • Use a Phillips screwdriver to remove the three 1.3 mm screws securing the battery and display connector cover.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  19. iPhone 13 Battery Replacement, Remove the battery and display connector cover: step 19, image 1 of 1
    • Remove the cover.
  20. iPhone 13 Battery Replacement, Disconnect the battery: step 20, image 1 of 2 iPhone 13 Battery Replacement, Disconnect the battery: step 20, image 2 of 2
    • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  21. iPhone 13 Battery Replacement, Disconnect the display cable: step 21, image 1 of 2 iPhone 13 Battery Replacement, Disconnect the display cable: step 21, image 2 of 2
    • Use a spudger or a fingernail to disconnect the display cable connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  22. iPhone 13 Battery Replacement, Unscrew the front sensor connector cover: step 22, image 1 of 1
    • Remove three screws securing the front sensor connector cover:
    • One 1.7 mm Phillips screw
    • One 1.3 mm Phillips screw
    • One 1.8 mm Y000 screw
  23. iPhone 13 Battery Replacement, Remove the front sensor connector cover: step 23, image 1 of 2 iPhone 13 Battery Replacement, Remove the front sensor connector cover: step 23, image 2 of 2
    • Swing the cover up from the center of the phone until the small clip by the edge of the phone unhooks.
  24. iPhone 13 Battery Replacement: step 24, image 1 of 2 iPhone 13 Battery Replacement: step 24, image 2 of 2
    • Remove the cover.
    • During reassembly, insert the clip on the left edge into its slot first, then hinge the rest of the cover into place.
  25. iPhone 13 Battery Replacement, Disconnect the front sensors: step 25, image 1 of 2 iPhone 13 Battery Replacement, Disconnect the front sensors: step 25, image 2 of 2
    • Use a spudger or a fingernail to disconnect the front sensor assembly cable connector.
  26. iPhone 13 Battery Replacement, Remove the screen: step 26, image 1 of 2 iPhone 13 Battery Replacement, Remove the screen: step 26, image 2 of 2
  27. iPhone 13 Battery Replacement, Unscrew the loudspeaker: step 27, image 1 of 1
    • Use a Phillips driver to remove the four 1.7 mm screws securing the loudspeaker.
  28. iPhone 13 Battery Replacement, Remove the loudspeaker: step 28, image 1 of 1
    • Remove the loudspeaker from the iPhone.
  29. iPhone 13 Battery Replacement, Locate the adhesive pull-tabs: step 29, image 1 of 3 iPhone 13 Battery Replacement, Locate the adhesive pull-tabs: step 29, image 2 of 3 iPhone 13 Battery Replacement, Locate the adhesive pull-tabs: step 29, image 3 of 3
    • The battery is secured to the rear case with four pieces of stretch-release adhesive—two on the bottom edge of the battery, and two on the top edge.
    • Each piece of adhesive has a black pull-tab at the end, which is lightly adhered to the edge of the battery.
    • In the following steps, you'll pull each tab to slowly stretch out the adhesive underneath the battery. These "command-strip" style adhesives lose their stick when stretched, so you can remove the battery with ease.
    • If the strips break, don't panic! They don't always work as intended. Keep reading for tips on removing broken strips.
  30. iPhone 13 Battery Replacement, Remove the stretch-release adhesive: step 30, image 1 of 3 iPhone 13 Battery Replacement, Remove the stretch-release adhesive: step 30, image 2 of 3 iPhone 13 Battery Replacement, Remove the stretch-release adhesive: step 30, image 3 of 3
    Buy
    • Caution: Don't jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals or catch fire.
    • Use the flat end of a spudger to gently lift up the edge of the top right battery adhesive pull-tab so that you can grab it with a pair of blunt tweezers.
    • Peel down the battery adhesive pull-tab to un-stick it from the top edge of the battery.
    • Repeat for the top left battery adhesive pull-tab.
  31. iPhone 13 Battery Replacement: step 31, image 1 of 3 iPhone 13 Battery Replacement: step 31, image 2 of 3 iPhone 13 Battery Replacement: step 31, image 3 of 3
    • Peel up the two remaining battery adhesive pull-tabs to un-stick them from the bottom edge of the battery.
  32. iPhone 13 Battery Replacement: step 32, image 1 of 1
    • Optionally, tilt the bottom of the phone up and apply a few drops of high-concentration (90% or higher) isopropyl alcohol to the bottom edge of the battery, and wait a minute. It'll help soften the adhesives, especially if the phone is old.
  33. iPhone 13 Battery Replacement: step 33, image 1 of 3 iPhone 13 Battery Replacement: step 33, image 2 of 3 iPhone 13 Battery Replacement: step 33, image 3 of 3
    • Grab the bottom right pull-tab with your fingers and slowly pull it away from the battery, toward the bottom of the iPhone.
    • Pull hard enough to maintain tension on the strip, but don't force it. Give it plenty of time to stretch and un-stick from under the battery.
    • Don't press down on the battery. Hold the iPhone firmly by its sides.
    • Keep the strip flat and unwrinkled. Try to pull evenly on the whole strip, rather than pulling mainly in the middle or on one side.
    • Pull at a low angle so the strip doesn't snag on the edge of the battery.
    • If the adhesive strip breaks off, try to retrieve it using your fingers or blunt tweezers, and continue pulling—but do not pry under the battery.
    • If any of the adhesive strips break off underneath the battery and can't be retrieved, try to remove the other strips, and then proceed as instructed below.
  34. iPhone 13 Battery Replacement: step 34, image 1 of 3 iPhone 13 Battery Replacement: step 34, image 2 of 3 iPhone 13 Battery Replacement: step 34, image 3 of 3
    • Grab the bottom left pull-tab with your fingers and pull it away from the battery, toward the bottom of the iPhone.
    • Follow the same procedure as with the previous strip: don't press down on the battery, keep the strip flat and unwrinkled, and pull at a low angle.
    • If the adhesive breaks off underneath the battery and can't be retrieved, continue with the next step.
  35. iPhone 13 Battery Replacement: step 35, image 1 of 3 iPhone 13 Battery Replacement: step 35, image 2 of 3 iPhone 13 Battery Replacement: step 35, image 3 of 3
    • You can optionally wrap the pull-tabs around the tips of blunt tweezers to make it easier to pull out the adhesive strip:
    • Use a pair of blunt tweezers to grab the entire width of the pull-tab.
    • Wrap the pull-tab and adhesive strip around the tips of the blunt tweezers.
    • Using the same procedure as before, pull the top right pull-tab to stretch and remove the adhesive strip. Try not to snag the adhesive on anything.
  36. iPhone 13 Battery Replacement: step 36, image 1 of 3 iPhone 13 Battery Replacement: step 36, image 2 of 3 iPhone 13 Battery Replacement: step 36, image 3 of 3
    • Lightly place two fingers on the center of the battery to prevent it from flinging out while removing the final adhesive strip.
    • Don't press down on the battery with excessive force.
    • Use a pair of blunt tweezers to pull and stretch the remaining tab to remove the final adhesive strip holding the battery in place.
    • If you removed all the adhesive strips successfully, skip the next step.
    • Otherwise, continue with the next step below.
  37. iPhone 13 Battery Replacement, How to remove a stuck battery: step 37, image 1 of 2 iPhone 13 Battery Replacement, How to remove a stuck battery: step 37, image 2 of 2
    • If you're still having trouble removing the battery, apply a few drops of high concentration (90% or higher) isopropyl alcohol under the edge of the battery in the area of the broken adhesive strip(s).
    • Tilt the phone up so the isopropyl alcohol can flow toward the adhesive strip.
    • Wait about one minute for the alcohol solution to weaken the adhesive.
    • Use an opening pick or the flat end of a spudger to gently lift the battery.
    • Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
  38. iPhone 13 Battery Replacement, Remove the battery: step 38, image 1 of 2 iPhone 13 Battery Replacement, Remove the battery: step 38, image 2 of 2
    • Remove the battery from the iPhone.
    • If there's any alcohol solution remaining in the phone, carefully wipe it off with a coffee filter or allow it to air dry before installing your new battery.
    • If your new battery didn't come with adhesive preinstalled, refer to this guide for help replacing the adhesive strips.
    • Perform a force restart after reassembly. This can prevent several issues and simplify troubleshooting.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 13 Answers community for help.
23 other people completed this guide.
Kyle Smith
41,105 Reputation
123 Guides authored
One Comment
Does anyone know if the kit comes with the tools as well or are the tools sold separately
Phinious and Ferbs - Reply
Past 24 Hours: 242
Past 7 Days: 1,563
Past 30 Days: 6,684
All Time: 109,146
