iPhone 8 Plus Screen Replacement
Video Overview
  1. iPhone 8 Plus Screen Replacement, Pentalobe Screws: step 1, image 1 of 1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.5 mm pentalobe screws from the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 8 Plus Screen Replacement, Mark your opening picks: step 2, image 1 of 3 iPhone 8 Plus Screen Replacement, Mark your opening picks: step 2, image 2 of 3 iPhone 8 Plus Screen Replacement, Mark your opening picks: step 2, image 3 of 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  3. iPhone 8 Plus Screen Replacement, Tape over any cracks: step 3, image 1 of 3 iPhone 8 Plus Screen Replacement, Tape over any cracks: step 3, image 2 of 3 iPhone 8 Plus Screen Replacement, Tape over any cracks: step 3, image 3 of 3
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  4. iPhone 8 Plus Screen Replacement, Anti-Clamp instructions: step 4, image 1 of 3 iPhone 8 Plus Screen Replacement, Anti-Clamp instructions: step 4, image 2 of 3 iPhone 8 Plus Screen Replacement, Anti-Clamp instructions: step 4, image 3 of 3
    Tool used on this step:
    Anti-Clamp
    $24.95
    Buy
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone 8 Plus Screen Replacement: step 5, image 1 of 3 iPhone 8 Plus Screen Replacement: step 5, image 2 of 3 iPhone 8 Plus Screen Replacement: step 5, image 3 of 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone 8 Plus Screen Replacement: step 6, image 1 of 2 iPhone 8 Plus Screen Replacement: step 6, image 2 of 2
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  7. iPhone 8 Plus Screen Replacement: step 7, image 1 of 1
    • The next three steps show how to separate the screen using a suction cup.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about 90 seconds in order to soften up the adhesive underneath.
  8. iPhone 8 Plus Screen Replacement: step 8, image 1 of 2 iPhone 8 Plus Screen Replacement: step 8, image 2 of 2
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
  9. iPhone 8 Plus Screen Replacement: step 9, image 1 of 3 iPhone 8 Plus Screen Replacement: step 9, image 2 of 3 iPhone 8 Plus Screen Replacement: step 9, image 3 of 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Insert an opening pick or other thin pry tool a few millimeters into the gap.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  10. iPhone 8 Plus Screen Replacement: step 10, image 1 of 3 iPhone 8 Plus Screen Replacement: step 10, image 2 of 3 iPhone 8 Plus Screen Replacement: step 10, image 3 of 3
    • Slide your pick around the corner and up the left edge of the phone, moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Stop near the top left corner of the display.
  11. iPhone 8 Plus Screen Replacement, Screen information: step 11, image 1 of 1
    • There's a delicate cable along the right edge of your iPhone. Don't insert your pick here, as you may damage the cable.
  12. iPhone 8 Plus Screen Replacement: step 12, image 1 of 3 iPhone 8 Plus Screen Replacement: step 12, image 2 of 3 iPhone 8 Plus Screen Replacement: step 12, image 3 of 3
    • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
  13. iPhone 8 Plus Screen Replacement: step 13, image 1 of 1
    • Gently pull up on the suction cup to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
  14. iPhone 8 Plus Screen Replacement: step 14, image 1 of 1
    • Pull on the small nub on the suction cup to remove it from the front panel.
  15. iPhone 8 Plus Screen Replacement: step 15, image 1 of 3 iPhone 8 Plus Screen Replacement: step 15, image 2 of 3 iPhone 8 Plus Screen Replacement: step 15, image 3 of 3
    • Slide an opening pick underneath the display along the top edge of the phone to loosen the last of the adhesive.
  16. iPhone 8 Plus Screen Replacement: step 16, image 1 of 2 iPhone 8 Plus Screen Replacement: step 16, image 2 of 2
    • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
  17. iPhone 8 Plus Screen Replacement: step 17, image 1 of 3 iPhone 8 Plus Screen Replacement: step 17, image 2 of 3 iPhone 8 Plus Screen Replacement: step 17, image 3 of 3
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
  18. iPhone 8 Plus Screen Replacement, Battery Disconnection: step 18, image 1 of 2 iPhone 8 Plus Screen Replacement, Battery Disconnection: step 18, image 2 of 2
    Magnetic Project Mat
    $19.95
    Buy
    • Remove four Phillips (JIS) screws securing the lower display cable bracket to the logic board, of the following lengths:
    • Two 1.3 mm screws
    • One 1.4 mm screw
    • One 2.7 mm screw
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
  19. iPhone 8 Plus Screen Replacement: step 19, image 1 of 1
    • Remove the lower display cable bracket.
  20. iPhone 8 Plus Screen Replacement: step 20, image 1 of 2 iPhone 8 Plus Screen Replacement: step 20, image 2 of 2
    • Use the point of a spudger to pry the battery connector up from its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  21. iPhone 8 Plus Screen Replacement, Display Assembly: step 21, image 1 of 2 iPhone 8 Plus Screen Replacement, Display Assembly: step 21, image 2 of 2
    • Use the tip of a spudger or a fingernail to disconnect the large lower display connector by prying it straight up from its socket.
    • To re-attach press connectors like this one, press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
  22. iPhone 8 Plus Screen Replacement: step 22, image 1 of 2 iPhone 8 Plus Screen Replacement: step 22, image 2 of 2
    • Disconnect the second lower display cable connector, directly behind the one you disconnected in the previous step.
  23. iPhone 8 Plus Screen Replacement: step 23, image 1 of 2 iPhone 8 Plus Screen Replacement: step 23, image 2 of 2
    • Remove the two tri-point Y000 screws securing the bracket over the front panel sensor assembly connector:
    • One 1.0 mm screw
    • One 1.2 mm screw
  24. iPhone 8 Plus Screen Replacement: step 24, image 1 of 1
    • Remove the bracket covering the front panel sensor assembly connector.
  25. iPhone 8 Plus Screen Replacement: step 25, image 1 of 2 iPhone 8 Plus Screen Replacement: step 25, image 2 of 2
    • Use the tip of a spudger or a fingernail to disconnect the front panel sensor assembly connector from its socket.
  26. iPhone 8 Plus Screen Replacement: step 26, image 1 of 1
  27. iPhone 8 Plus Screen Replacement, Home/Touch ID Sensor: step 27, image 1 of 2 iPhone 8 Plus Screen Replacement, Home/Touch ID Sensor: step 27, image 2 of 2
    • Remove the four Y000 screws securing the bracket over the home/Touch ID sensor:
    • One 1.2 mm screw
    • Three 1.3 mm screws
    • During reassembly, be careful not to overtighten these screws, or your home button may not work.
  28. iPhone 8 Plus Screen Replacement: step 28, image 1 of 1
    • Remove the bracket that secures the home/Touch ID sensor.
  29. iPhone 8 Plus Screen Replacement: step 29, image 1 of 3 iPhone 8 Plus Screen Replacement: step 29, image 2 of 3 iPhone 8 Plus Screen Replacement: step 29, image 3 of 3
    • Pry under the left edge of the home button cable connector to disconnect it from its socket.
    • If the entire connector begins to flip up without separating, press down on the cable at the top edge of the connector with the flat of your spudger, while simultaneously prying up the left edge of the connector. Be very careful not to damage the cable or connector, or you will permanently disable the sensor.
  30. iPhone 8 Plus Screen Replacement: step 30, image 1 of 1
    • Heating the area around the home/Touch ID sensor will help soften the adhesive holding its delicate cable in place, making it easier to remove safely.
    • Flip the display assembly over. Use a hairdryer or prepare an iOpener and apply it to the lower edge of the display for about 90 seconds in order to soften up the adhesive underneath.
    • Don't overheat the display. It should be slightly too hot to touch comfortably.
  31. iPhone 8 Plus Screen Replacement: step 31, image 1 of 3 iPhone 8 Plus Screen Replacement: step 31, image 2 of 3 iPhone 8 Plus Screen Replacement: step 31, image 3 of 3
    • Use an opening pick to gently separate the adhesive holding the home/Touch ID sensor cable to the back side of the display panel.
  32. iPhone 8 Plus Screen Replacement: step 32, image 1 of 1
    • Remove the home/Touch ID sensor assembly by lifting it through the front side of the display.
    • To reinstall, first feed the cable through the hole in the front of the display as shown.
    • Your replacement part may come with extra Y000 screws already installed near the Home Button. Remove the unnecessary screws so that you can reinstall the home button bracket.
311 other people completed this guide.
Jeff Suovanen
427,941 Reputation
259 Guides authored
iFixit Member of iFixit
Staff
135 Members
16,764 Guides authored
36 Comments
Very useful information…
Flica Hussey - Reply
Has anyone found out any info about replacing the Apple iPhone 8 Front glass. Last I checked Apple had made it that if you install a non OEM screen and updates their phone, it will brick there phone. I have not been fixing any iPhone 8’s or iPhone x’s due to this. I So if someone knows if this has been resolved or if this still holds true can you please let me know. Also, Fixing back glass. From what I have seen they use some crazy glue. Does anyone have any methods on a easy way to replace back glass on the iPhone 8’s ? do you still basically have to gut the phone ? what kind of glue is used to glue it back on? Any help with these issues would greatly be appreciated I have been repairing phones for over 8 years + and turning away customers because apple is so dumb with these things upsets me greatly. I loved repairing iPhone up until this point. Help please.
service - Reply
Replacing the screen will not Brick the iPhone, although the 8/8Plus & iPhone X all have an issue with the Ambient Sensor when a new screen is fitted. Although a way around this is to use a EEPROM device to copy the firmware from the original screen. It is also rumored that Apple are fixing the Ambient Sensor issue in iOS 12.
Donald -
Why don't you just throw an oem replica decal over the back glass and call it good. Any more time spent on something that is designed to break & devalue your device into a state beyond reasonable repair efforts, to inevitably promote purchase of a newer model, should be treated with scorn and covered with cheap adhesive decals from China.
SalvagedBandit -
Anyone know if the ambient sensor is fixed?
alexaamo91 - Reply
Past 24 Hours: 62
Past 7 Days: 384
Past 30 Days: 1,910
All Time: 386,852
