This teardown is not a repair guide. To repair your Apple USB Power Adapter, use our service manual.
  1. Apple USB Power Adapter Teardown, Separating the input panel: step 1, image 1 of 3 Apple USB Power Adapter Teardown, Separating the input panel: step 1, image 2 of 3 Apple USB Power Adapter Teardown, Separating the input panel: step 1, image 3 of 3
    • Use a hammer and a small chisel to carefully force the input panel open
    • Clamping the device helps prop the input panel open but, do not pull the panel away from the device forcefully, as there are small wires connected to the device components.
    • Be careful not to force the chisel into the device as you could damage internal components.
  2. Apple USB Power Adapter Teardown, Removing plastic casing: step 2, image 1 of 2 Apple USB Power Adapter Teardown, Removing plastic casing: step 2, image 2 of 2
    • Use dyke and pliers to cut outside casing to pry open the shell and remove the circuitry.
    • Recommend using hand saw to cut around the plastic.
    • Be careful not to cut forcefully as to prevent the internal components from getting damaged.
  3. Apple USB Power Adapter Teardown, Isolating internal components: step 3, image 1 of 3 Apple USB Power Adapter Teardown, Isolating internal components: step 3, image 2 of 3 Apple USB Power Adapter Teardown, Isolating internal components: step 3, image 3 of 3
    • Isolate the internal electrical components from the casing
    • Recommend unsoldering the wires from the input panel.
    • For help desoldering connections, follow this useful guide on How To Solder and Desolder Connections.
    • Use caution when soldering. The heated tip may cause damage to the board, the components, or burn you.
  4. Apple USB Power Adapter Teardown, Accessing individual components: step 4, image 1 of 3 Apple USB Power Adapter Teardown, Accessing individual components: step 4, image 2 of 3 Apple USB Power Adapter Teardown, Accessing individual components: step 4, image 3 of 3
    • Unsolder components that connect to the bottom and top circuit boards.
    • Detach the top and bottom circuit boards from the plastic separator.
  5. Apple USB Power Adapter Teardown, Exploration: step 5, image 1 of 2 Apple USB Power Adapter Teardown, Exploration: step 5, image 2 of 2
    • Observe that once the circuit boards are separated individual components can be accessed.
Juan Gonzalez
422 Reputation
2 Guides authored
Cal Poly, Team S18-G1, White Winter 2019 Member of Cal Poly, Team S18-G1, White Winter 2019
CPSU-WHITE-W19S18G1
4 Members
21 Guides authored
0 Comments
Past 24 Hours: 8
Past 7 Days: 39
Past 30 Days: 204
All Time: 15,754
