This teardown is not a repair guide. To repair your Huawei P30 Pro, use our service manual.
  1. Huawei P30 Pro Teardown, Huawei P30 Pro Teardown: step 1, image 1 of 3 Huawei P30 Pro Teardown, Huawei P30 Pro Teardown: step 1, image 2 of 3 Huawei P30 Pro Teardown, Huawei P30 Pro Teardown: step 1, image 3 of 3
    • Let's put the Huawei P30 Pro into perspective with a glance at the specs:
    • 6.47" OLED display with FHD+ (2340 × 1080) resolution
    • 8-core Huawei Kirin 980 Processor with dual neural-network processing units and Mali-G76 MP10 GPU
    • 6 GB RAM and 128 GB onboard storage (configurable to 8 GB RAM and up to 512 GB storage)
    • Leica "quad" rear camera with 40 MP wide-angle (ƒ/1.6 with OIS) + 20 MP ultra-wide angle (ƒ/2.2) + 8 MP telephoto (ƒ/3.4 with OIS) + Huawei time-of-flight module—plus, a 32 MP selfie cam (ƒ/2.0)
    • A new earpiece speaker technology called "Acoustic Display Technology," plus an in-display fingerprint sensor
    • USB-C charging port (but no headphone jack)
    • IP68 water/dust-resistance rating
  2. Huawei P30 Pro Teardown: step 2, image 1 of 3 Huawei P30 Pro Teardown: step 2, image 2 of 3 Huawei P30 Pro Teardown: step 2, image 3 of 3
    • We pull out yesteryear's P20 Pro and put it next to Huawei's latest camera prodigy for some quick comparisons:
    • The P30 Pro (left/bottom) is 3 mm taller, 0.61 mm thicker, and a little less wide (0.5 mm) than its predecessor.
    • Despite the home button and earpiece speaker grille vanishing behind the screen, the P30 Pro has grown taller.
    • The power and volume buttons are still where they were last year.
    • Along the bottom edge of the phone we see the USB-C port remains, while the four microphone holes mirroring the speaker holes have been cut down to one to make room for the SIM card slot.
    • Make sure you put that SIM eject tool in the correct hole ...
  3. Huawei P30 Pro Teardown: step 3, image 1 of 3 Huawei P30 Pro Teardown: step 3, image 2 of 3 Huawei P30 Pro Teardown: step 3, image 3 of 3
    Tool used on this step:
    iSclack
    $24.99
    Buy
    • As we begin our teardown, we notice an extremely tight gap between the frame and the back glass, barely noticeable to the naked eye.
    • Manufacturing tolerances seem to keep shrinking—making it more difficult to open many of these glued-shut devices. Is this the price for IP68?
    • With a little heat, the iSclack, and an opening pick, we manage our way through the back cover adhesive.
    • Of course, the back cover is made of glass to increase the crackability rating of the device make wireless charging possible.
  4. Huawei P30 Pro Teardown: step 4, image 1 of 3 Huawei P30 Pro Teardown: step 4, image 2 of 3 Huawei P30 Pro Teardown: step 4, image 3 of 3
    Mako Driver Kit - 64 Precision Bits
    $39.95
    Buy
    • We equip ourselves with the Precision Bit Driver and a Phillips bit from our Mako Driver Set, which is (spoiler alert) the only bit we need until the end of this teardown. For that, we're pleased.
    • Next out is the wireless charging coil attached to the motherboard cover, which also carries some antennas and a strange orange flex cable to bridge two contacts—what for, we're not sure.
    • This charging coil not only charges the phone, but also works in reverse to charge your mouse, electrical razor, or toothbrush—no kidding.
    • It seems that for 2019, reverse charging is becoming standard equipment on flagship phones.
  5. Huawei P30 Pro Teardown: step 5, image 1 of 3 Huawei P30 Pro Teardown: step 5, image 2 of 3 Huawei P30 Pro Teardown: step 5, image 3 of 3
    • With the phone now fully open, we head straight for the cameras. First out is the new periscope-style camera module that is said to make up to 50x zoom possible.
    • Instead of resorting to a massive camera bump, this module is rotated 90° from the aperture, laying flat in the phone with a prism refracting the light onto the sensor.
    • But wait—it seems this module isn't used between 1x-5x zoom, coming into play beyond 5x zoom only.
    • The P30 Pro has five cameras in total. Starting at top left: a 20 MP ultra-wide-angle, a 40 MP wide-angle with the Time-of-Flight camera next to it, the 8 MP telephoto (for up to 50x zoom), and of course at top right is the front-facing camera with an impressive 32 MP.
    • Interestingly, the 40 MP camera sensor switched from an RGGB (Red/Green/Green/Blue) bayer filter to a RYYB (Red/Yellow/Yellow/Blue) pattern. This pattern is said to increase light sensitivity, and could help with contrast since they ditched the monochrome sensor from last year's P20 Pro.
  6. Huawei P30 Pro Teardown: step 6, image 1 of 2 Huawei P30 Pro Teardown: step 6, image 2 of 2
  7. Huawei P30 Pro Teardown: step 7, image 1 of 2 Huawei P30 Pro Teardown: step 7, image 2 of 2
    • For further insight, we peel off the shields and seek out some chips:
    • SK hynix H9HKNNNFBMAU LPDDR4X—with the Huawei Kirin 980 layered underneath
    • Micron MTFC128GAOANAM-WT 128 GB flash storage
    • HiSilicon Hi6405 audio codec
    • HiSilicon Hi6363 RF transceiver
    • Skyworks SKY78191-11 front end module for WCDMA/LTE
    • Qorvo QM77031 front end module
    • HiSilicon Hi6H02T and Hi6H01T low noise amplifier/RF switch modules
  8. Huawei P30 Pro Teardown: step 8, image 1 of 3 Huawei P30 Pro Teardown: step 8, image 2 of 3 Huawei P30 Pro Teardown: step 8, image 3 of 3
    • Remember that missing earpiece speaker grille on the front of this phone? That's thanks to Huawei's "Acoustic Display Technology" speaker, which works like a vibration speaker (a.k.a. structure-borne driver).
    • This works almost like a "normal" speaker—but instead of vibrating a membrane to produce sound waves, it vibrates a rigid surface (the glass screen), transforming the screen into a speaker.
    • The driving part of this module consists of a coil with a magnet in the middle. It is coupled with the part that vibrates the screen, which is glued to the back of the display.
    • Don't confuse it with the conventional vibration motor for alerts, which is mounted on the metal frame next to it.
  9. Huawei P30 Pro Teardown: step 9, image 1 of 3 Huawei P30 Pro Teardown: step 9, image 2 of 3 Huawei P30 Pro Teardown: step 9, image 3 of 3
    • On our way to the fingerprint sensor, we fish out the USB-C port, attached to a long interconnect cable.
    • If you opt to charge wirelessly, the wear-and-tear on this port should be greatly reduced—but when it does fail, it's nice to see that it comes out separately from the daughterboard and SIM card reader.
    • We're all in favor of more major component modularity (or MMCM, as no one calls it). This makes for greatly expedited repairs compared with, say, the soldered ports on the new Galaxy S10 line.
    • While we're here, we extract the traditional (non-display-based) loudspeaker module.
  10. Huawei P30 Pro Teardown: step 10, image 1 of 3 Huawei P30 Pro Teardown: step 10, image 2 of 3 Huawei P30 Pro Teardown: step 10, image 3 of 3
    • We finally reach the fingerprint sensor, mounted quite close to the bottom edge of the phone. What is the maximum thumb length here for comfortable unlocking?
    • This fingerprint sensor is the same Goodix GM185 optical scanner as seen in the OnePlus 6T, the Xiaomi Mi 9, and the Vivo Nex S.
    • Optical sensor, you say? That makes a total of six cameras in this phone, technically speaking.
  11. Huawei P30 Pro Teardown: step 11, image 1 of 3 Huawei P30 Pro Teardown: step 11, image 2 of 3 Huawei P30 Pro Teardown: step 11, image 3 of 3
    • The battery comes with these handy pull tabs, previously seen in the Mate 20 Pro.
    • While the tabs labelled "1" and "2" are somewhat useless (don't mistake them for adhesive pull tabs), number 3 helps us lever the energy cell out of the case.
    • This battery delivers a typical capacity of 16.04 Wh (4200 mAh @ 3.82 V)—which is on par with the Mate 20 Pro, while beating the Galaxy S10+ (15.79 Wh), not to mention the iPhone XS Max (12.08 Wh).
  12. Huawei P30 Pro Teardown: step 12, image 1 of 3 Huawei P30 Pro Teardown: step 12, image 2 of 3 Huawei P30 Pro Teardown: step 12, image 3 of 3
    • Moving on to the screen, we find the second half of the glass-vibrating earpiece speaker module stuck to the back of the display as we fight through the adhesive.
    • Similar to the back cover, the gap between the frame and the display is virtually non-existent—and the slightly-curved edges of the display don't help, either. We're pretty sure this display is done for after the heat, cutting, and prying it's endured.
    • The strong adhesive strings between the frame and the display fight us like Spider-Man trying to reassemble a boat.
    • The question that arises for us is: If your screen should break or crack toward the top half of the phone, will there be any sound distortion with the new earpiece speaker technology? Will it even work at all? We'll investigate—stay tuned.
  13. Huawei P30 Pro Teardown: step 13, image 1 of 1
    • Having finished with the P30 Pro we focus in on the important stuff:
    • A tightly-glued-shut device with the barest sliver of a gap for entry
    • An inside crammed with nifty optical tech like a periscope camera and an in-display fingerprint sensor
    • A plus-sized battery with some pull tabs for grappling with the glue
    • And a tall screen with the earpiece speaker glued to its back.
    • Taking everything into account, it is time to zoom in on the score.
  14. Final Thoughts
    • A single Phillips driver is all we need to handle the screws.
    • Most components are modular and can be replaced independently—except for one half of the earpiece speaker.
    • Battery replacement is possible, if you're willing to fight through the glue.
    • Heavily glued-down glass both front and back means greater risk of breakage, and makes repairs difficult to start.
    • Screen repairs require a lot of disassembly while battling tough adhesive (back, battery and screen).
    Repairability Score
    4
    Repairability 4 out of 10
    (10 is easiest to repair)
Tobias Isakeit
118,058 Reputation
189 Guides authored
37 Comments
And P30 please!
magnus - Reply
Tnx for disassembly explanation. What is under PCB stack?
Michel Markovski - Reply
Is there any chance you will do a overview of the front internals for a wallpaper? I along with other people would be thrilled to have it :)
Robert Louth - Reply
Hi Robert,
You can find the wallpaper here! Enjoy!
https://ifixit.org/blog/15777/huawei-p30...
Arthur Shi -
Orange flex looks like grounding flex. It would be nice to see what is other side of that part.
Tony Vahtera - Reply
Past 24 Hours: 18
Past 7 Days: 186
Past 30 Days: 876
All Time: 176,907
