The first tablet from Acer's Iconia Tab B1 family, Acer Iconia Tab B1-A71 was announced in January 2013.
21 Questions View all
Why is my picture in negative
My acer tablet has not been dropped or damaged to my knowledge. When I turn it on, the colour is all in negative. I've tried resetting and even just a simple turn off and on. Does anyone know if this can be sorted or does it need to be repaired by a professional.
Any help will be grateful
Thankyou
Score 3
3 Comments:
same goes to me. i didnt dropped it and when i turned it on after charging all the pictures turn negative.
by
have you tried to go to settings - Accessibility - Negative Colors
by
Yes I have tried setting_accessibility. But could not fine negative colors....
by
Add a comment
You will need to turn of color inversion. Go to settings, click accessibility, scroll to the bottom, then click color inversion. That should fix it!
Add a comment
Most likely you have cracked resistor at lcd flex cable
You need to replace it with working one
https://imgur.com/a/3W99K
Add a comment
Add your answer
Gemma will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 1,275
