Repair Guide and Support for Lightning McQueen RC Car toy. 1:24 scale RC car from Dickie Toys. Article number(s): 203089501 for basic Lightning McQueen 203089538 for metallic variant
8 Questions View all
How can I remove the rear wheels?
The car does not have proper traction and I think there is a problem in the gearbox between electrical engine and rear wheels. I disassembled the car but I could not take out the engine and gear box because of the rear axle. I tried to pull off the rear wheels to remove the axle but it did not work. Any ideas how to do that?
Score 1
2 Comments
If you supply pictures someone may be able to help you further.
by
I'm facing same problem from the very day it was delivered to me. Need urgent service
by
Add a comment
1 Answer
Most Helpful Answer
The answer is: brute force.
The only way to remove the axle is by taking the wheels off first. They are pretty tight, but I managed to pry them off using a fork. Insert the fork all the way down behind the wheels, with the axle in between the tines of the fork. This will prevent the wheel from getting too damaged. Then use the leverage of the fork to pry the wheels off.
Score 2
2 Comments:
On behalf of the5-year old boys community, THANK YOU!
by
Thank You!!
This helped me to fix Lightning (again).
My son is very happy now.
My wife not, because i bend the fork 🙈
by
Add a comment
Add your answer
steffen.ruefer will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 46
All Time: 5,784
