There are so many things we could do if we only knew how. This area aims to catalog most specialized skills necessary to perform certain kinds of repairs.
495 Questions View all
What is the best way to dry used desiccant Silica-Gel?
I like to keep gadgets together with the accessories - an ideal way to store is a ziploc bag. Condensation is a worry with all electronics - therefore I want to use the small bags of desiccant that come with all sort of things.
What is the best way to dry these / restore them before use?
Score 5
1 Comment
I have a larger commercial product that I keep in my Camara Case. It has printed on its Case "Reactivate 3 hours at 300 F". Mine is about 4" x 2" x 1/2".
by
Add a comment
Chosen Solution
Let the packets bake on a cookie sheet in your oven at 150 degrees for 12-18 minutes or so. Allow them to cool and they should be ready to go. Alternatively, you can find new ones on the internet for a relatively low cost.
Score 12
3 Comments:
I accepted this answer as it attracted a score of 3 - meaning to me others think too this is the may to go. Thank You
by
Put the containers you intend to store the gel in the oven with the gel (air tight ones). Unless your camera equipment is in airtight containers the gel won't be effective for more than a short time, so you would have to change them regularly, as they will draw moisture from the wider area and become useless quickly
by
I know it's been a while but did you mean 150 degrees Fahrenheit or Celsius?
by
Add a comment
dry in a food dehydrator 120 f or 50 c for 2 or more hours i do this with color changing this works good
Score 3
2 Comments:
Awesome... This info was really helpful. You should get more up-votes for this, definitely!
by
From what I've read, the colour changing type of silica packs should not be used anywhere near food items as they contain cobalt chloride, so unless you don't use your food dehydrator or oven for food, I wouldn't recommend those at all.
by
Add a comment
Just leave them a day in the sun, it will do.
Score 1
1 Comment:
Actually, that depends on where you live. If you're in a very low humidity area, might work. In Florida? Forget it!
by
Add a comment
IF it is a color changing Silica Gel, it can be reheated to 248 degrees Farenheit or 120 degrees Celsius to reset the colour change. As soon as the color has reverted, it can be re-used.
Score 1
Add a comment
leave it in the sun ...
some say put in oven or microwave, but limited tries...
perhaps for long term, can consider a dry box.
Score 1
Add a comment
silica gels adsorb moisture, so simply drying them under sun is simple technique...
Score -1
3 Comments:
If you liked miguel answer just vote it up, don't repeat it.
by
well, if u see it repeated, then you got better lots of time to see who repeats others, keep going.
by
by
Add a comment
Add your answer
Spikey2 will be eternally grateful.
Past 24 Hours: 15
Past 7 Days: 115
Past 30 Days: 603
All Time: 44,962
