Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Questions View all
Back panel will not slide back on?
I followed the guides within here to take apart my iPhone 4. And made sure to follow and remember every screw I took out, etc. My question is, whenever I go back to slide the back cover back on...it will not fully slide down into position for the two holes to screw it in place...it seems to be "stuck"... any ideas?
Score 2
Add a comment
Chosen Solution
you need to put a little bit of force, and check out the outter frame that it is aligned with the housing as u slide it on. :)
Score 5
3 Comments:
Thankyou! Put a little more force on it, and bingo, "clicked" right into place no problem. Thanks! :)
by
Please "accept" an answer if it solved your problem so that it can be archived for others to learn from. Thanks
by
You guys helped me out too! I thought I was going to have to reassemple everything. Then I was scared to apply more pressure. Thanks Guys! Who needs apple care?! IFIXIT!
by
Add a comment
This has happened to me a lot and i have found that the reason being, for me at least, is that i forget to make sure the 6 side screws (with washers) aren't tighten all the way. After i retighten those it fits like a charm!
Score 1
Add a comment
I just broke the !@#$ out of hte back of my iphone doing htis
Add a comment
Add your answer
Ryan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 24
All Time: 9,024
